Still running poorly, 914/6... |
Lawrence |
Apr 9 2003, 06:42 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
It warmed up a little yesterday, so I worked on the /6 when I got home from work.
Replaced two fuel filters, and remounted the pump, that seems to have come a bit loose. I had hoped that replacing fuel filters would clear up the running issue. No luck. The car runs poorly - under load/acceleration it hiccups, spits, backfires. Once I get it to a cruising speed, it's not too horrible. The plug wires ore OEM, and only have a couple thousand miles on them. I checked the cap and rotor, and they looked okay. I'll try the new coil from Summit tonight. Any thoughts or suggestions? -Rusty |
Lawrence |
Apr 9 2003, 08:43 AM
I swapped the stock CD box with a Permatune. The car had been setting for a little bit before the swap.
Swapping back didn't seem to help. I really don't know if the running problem was coincidence or not. The car has points in a Bosch dizzy. Is it possible that the increased output of the Permatune damaged the points enough that the car would run like crap at higher RPMs and under load? -Rusty |
Lo-Fi Version | Time is now: 1st June 2024 - 03:13 AM |
