| tornik550 |
Dec 14 2010, 08:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently tore apart my engine. I found that a part of the case was missing. Kind of hard to describe so I took a picture. It is on the passenger side below the main bearing that lies between cylinders 3/4. I did not find a hunk of metal in the oil, I think that the issue may have been there on the last rebuild.
Is this going to cause me any issues. Is there anything that I should do to fix it? I should mention that I am cheap and don't want to spend any money. Attached image(s)
Dr Evil Pic? Man, you sure have some luck... Dec 14 2010, 08:48 PM
tornik550 I think its 10% luck, 90% stupidity. For once, I ... Dec 14 2010, 08:57 PM
messix looks bad to me.
the area missing would give supp... Dec 14 2010, 08:57 PM
Dr Evil Reminds me of a patient I saw today:
Me - Do you ... Dec 14 2010, 09:01 PM
tornik550
Me - Do you... Dec 14 2010, 09:09 PM
messix on looking closer.... thats at the lower cam boss.... Dec 14 2010, 09:14 PM
tornik550
on looking closer.... thats at the lower cam boss... Dec 14 2010, 09:18 PM
messix
on looking closer.... thats at the lower cam bos... Dec 14 2010, 09:26 PM
r_towle Is that the boss that holds the sump bolt in place... Dec 14 2010, 09:21 PM
Mark Henry
Is that the boss that holds the sump bolt in plac... Dec 14 2010, 09:45 PM
r_towle
Is that the boss that holds the sump bolt in pla... Dec 14 2010, 10:00 PM
bdstone914 Nope you cant mix and match halves, They are match... Dec 14 2010, 09:23 PM
tornik550 Just found a reference to this problem on tunacan.... Dec 14 2010, 09:37 PM
McMark
Absolutely. You'll be $$$... Dec 14 2010, 10:49 PM
sww914 These cases are cheap and plentiful. Unless there... Dec 15 2010, 12:11 AM
Cap'n Krusty While cases may be cheap and plentiful, GOOD cases... Dec 15 2010, 01:21 AM
Jake Raby That's what we refer to as the syndrome.... Ha... Dec 15 2010, 04:27 AM
tornik550 How bout some JB Weld? Just kidding.
What should... Dec 15 2010, 07:52 AM
sean_v8_914 this kinda relates to the deep sump thread since t... Dec 15 2010, 08:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:09 AM |
