> Is this a big problem- Case issue
tornik550
post Dec 14 2010, 08:45 PM
I recently tore apart my engine. I found that a part of the case was missing. Kind of hard to describe so I took a picture. It is on the passenger side below the main bearing that lies between cylinders 3/4. I did not find a hunk of metal in the oil, I think that the issue may have been there on the last rebuild.
Is this going to cause me any issues. Is there anything that I should do to fix it? I should mention that I am cheap and don't want to spend any money.
r_towle
post Dec 14 2010, 09:21 PM
Custom Member
Is that the boss that holds the sump bolt in place...
The one that cracks off when over tightened?
Rich
Mark Henry
post Dec 14 2010, 09:45 PM
that's what I do!
QUOTE(r_towle @ Dec 14 2010, 10:21 PM) *
Rich
Why the question mark Rich?....That's exactly what go on.
Bet it was always leaking from the sump plate.
Case is pooched get another. The fix will cost more than the case.
tornik550   Is this a big problem- Case issue   Dec 14 2010, 08:45 PM
Dr Evil   Pic? Man, you sure have some luck...   Dec 14 2010, 08:48 PM
tornik550   I think its 10% luck, 90% stupidity. For once, I ...   Dec 14 2010, 08:57 PM
messix   looks bad to me. the area missing would give supp...   Dec 14 2010, 08:57 PM
Dr Evil   Reminds me of a patient I saw today: Me - Do you ...   Dec 14 2010, 09:01 PM
tornik550   Reminds me of a patient I saw today: Me - Do you...   Dec 14 2010, 09:09 PM
messix   on looking closer.... thats at the lower cam boss....   Dec 14 2010, 09:14 PM
tornik550   on looking closer.... thats at the lower cam boss...   Dec 14 2010, 09:18 PM
messix   on looking closer.... thats at the lower cam bos...   Dec 14 2010, 09:26 PM
r_towle   Is that the boss that holds the sump bolt in place...   Dec 14 2010, 09:21 PM
Mark Henry   Is that the boss that holds the sump bolt in plac...   Dec 14 2010, 09:45 PM
r_towle   Is that the boss that holds the sump bolt in pla...   Dec 14 2010, 10:00 PM
bdstone914   Nope you cant mix and match halves, They are match...   Dec 14 2010, 09:23 PM
tornik550   Just found a reference to this problem on tunacan....   Dec 14 2010, 09:37 PM
McMark   Absolutely. You'll be $$$...   Dec 14 2010, 10:49 PM
sww914   These cases are cheap and plentiful. Unless there...   Dec 15 2010, 12:11 AM
Cap'n Krusty   While cases may be cheap and plentiful, GOOD cases...   Dec 15 2010, 01:21 AM
Jake Raby   That's what we refer to as the syndrome.... Ha...   Dec 15 2010, 04:27 AM
tornik550   How bout some JB Weld? Just kidding. What should...   Dec 15 2010, 07:52 AM
sean_v8_914   this kinda relates to the deep sump thread since t...   Dec 15 2010, 08:07 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:03 AM
