| tornik550 |
Dec 14 2010, 08:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently tore apart my engine. I found that a part of the case was missing. Kind of hard to describe so I took a picture. It is on the passenger side below the main bearing that lies between cylinders 3/4. I did not find a hunk of metal in the oil, I think that the issue may have been there on the last rebuild.
Is this going to cause me any issues. Is there anything that I should do to fix it? I should mention that I am cheap and don't want to spend any money. Attached image(s)
| Jake Raby |
Dec 15 2010, 04:27 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
That's what we refer to as the syndrome.... Happens all the time from medieval mechanics with the precision of a brick..
It can be repaired, cost about 250 bucks to do it right. Good cases are hard to find, I now charge 1k for an inspected case if the customer's core is bad... We build from the customers supplied core primarily. Cores have become priceless. Most people don't know what to look at when inspecting a case. |
tornik550 Is this a big problem- Case issue Dec 14 2010, 08:45 PM
Dr Evil Pic? Man, you sure have some luck... Dec 14 2010, 08:48 PM
tornik550 I think its 10% luck, 90% stupidity. For once, I ... Dec 14 2010, 08:57 PM
messix looks bad to me.
the area missing would give supp... Dec 14 2010, 08:57 PM
Dr Evil Reminds me of a patient I saw today:
Me - Do you ... Dec 14 2010, 09:01 PM
tornik550
Me - Do you... Dec 14 2010, 09:09 PM
messix on looking closer.... thats at the lower cam boss.... Dec 14 2010, 09:14 PM
tornik550
on looking closer.... thats at the lower cam boss... Dec 14 2010, 09:18 PM
messix
on looking closer.... thats at the lower cam bos... Dec 14 2010, 09:26 PM
r_towle Is that the boss that holds the sump bolt in place... Dec 14 2010, 09:21 PM
Mark Henry
Is that the boss that holds the sump bolt in plac... Dec 14 2010, 09:45 PM
r_towle
Is that the boss that holds the sump bolt in pla... Dec 14 2010, 10:00 PM
bdstone914 Nope you cant mix and match halves, They are match... Dec 14 2010, 09:23 PM
tornik550 Just found a reference to this problem on tunacan.... Dec 14 2010, 09:37 PM
McMark
Absolutely. You'll be $$$... Dec 14 2010, 10:49 PM
sww914 These cases are cheap and plentiful. Unless there... Dec 15 2010, 12:11 AM
Cap'n Krusty While cases may be cheap and plentiful, GOOD cases... Dec 15 2010, 01:21 AM
tornik550 How bout some JB Weld? Just kidding.
What should... Dec 15 2010, 07:52 AM
sean_v8_914 this kinda relates to the deep sump thread since t... Dec 15 2010, 08:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:02 AM |
