draganc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States ![]() |
Hi everybody,
I’m having a leak issue at the taco place and was wondering if you have some advice or experienced similar issue. It appears that the plate leaks only in one area – see picture. The engine has been sitting on my work bench for a few months after rebuild, hence is leaking even at cold temp. - I checked the plate on a mirror and it appears to be flat and the overall condition looks very good – no nicks nor bents or scratches at the sealing surface. - New o-ring and copper washer have been installed. - The M6x10 hex screws have been tighten to spec. - The crank opening measures 84.2mm, the taco plate’s o-ring surface measures 76mm and the o-ring is 4mm thick. It takes only a little bit of force to put the plate in place with mounted o-ring and it appears that plate is already touching the crank-case w/o torquing down the screws. Any ideas or suggestions? Thanks, Dragan ![]() ![]() |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Oooo, purty!
Lo-Fi Version | Time is now: 10th June 2024 - 10:07 AM |
