> WOT: SOHC 2.5 Subaru Head Gasket Leak
yeahmag
post Dec 16 2010, 01:03 AM
I'm 95% sure my 2003 Legacy has the dreaded external HG leak. Both sides appear to be leaking oil slightly and the rear of the drivers side appears to be leaking coolant. I plan on trying the Subaru "Seal Conditioner", but have little faith...
Anyone done one of these before? If I've built a Type IV can I do this?
I'd probably yank the motor and just do both to get it over with.
tradisrad
post Dec 16 2010, 06:23 PM
i've got a subie and dealt with the head gaskets albeit my is a DOHC '99. When you do the job be sure to use subaru parts. I replaced mine with aftermarket parts and after a few months the valve cover gasket and grommets started to leak oil; they were cracked and hard. I fear that the head gaskets will have the same fate...
I had the engine out in about 6 hours; I took it slow and worked alone until the engine pull. I used a cherry picker and an engine stand. While you are in there it would be wise to repalce other parts like the timing belt, water pump etc...
good luck
- Lo-Fi Version Time is now: 6th July 2025 - 11:35 AM
