My car refuses to shift into 2 gear, I have no clue were to start |
weird_looking_cactus |
Mar 19 2004, 10:18 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
When I had the car running and was able to drive it the car, it would not shift into second gear. It had a pushing filling on it when I would try to go into that gear. Also even though I have the clutch all the way in and changing gears like from reverse to first it would make a big grinding noise but only once in a while. So Im thinking I need to tighten my cable to stop the grinding noise. But I have no clue about how to fix second gear. My car is a 1975 2.0 with side shifter. Thanks for those who help.
Bleyseng |
Mar 28 2004, 10:04 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Use a cobalt drill bit and a Easyout to remove it. The bottom of it is a cone shape that fits into the shift rod. If you just drill it out all the way you will have problems reinstalling. Shoot some PB Blaster in there to loosen it up also. Order a new cone screw to use.
I use a (I think) a 5mm allen (hex) that on a socket so I can get good purchase in it to remove them. When they a cranked down the cone screws are hard to remove. If you are using a hand allen key to remove it, it will be hard. Geoff |
Lo-Fi Version | Time is now: 8th June 2024 - 11:57 AM |
