end cap install, installing window/door end caps late model |
eastbay851 |
Dec 21 2010, 01:14 PM
Newbie Group: Members Posts: 39 Joined: 29-November 10 From: california Member No.: 12,438 Region Association: None |
hi all. i have a bit of a modified 75.... 13b rotary, 911 front end, scraped and filled, camera-monitor system in place of rear views and i am now stumped.... silly i know. after re-upholstering the door panels i went to install the new (914rubber) door/window end caps and cannot do it. the window glass is in the way of the inside screw. do i have to drop the window assembly to install these 2 insignificant widgets? you could probably sense my frustration. this is like traveling across the pacific to finally getting to hawaii and the tide is out so you can t dock and you have to walk the last 200 yards(meters for you euros.) thanks for your help.
76-914 |
Dec 21 2010, 03:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, you can loosen the regulator enough to drop the window out of the way. I think that f*&^%ng little phillips screw was a major PITA.
Lo-Fi Version | Time is now: 8th June 2024 - 01:05 AM |
