| VaccaRabite |
Dec 20 2010, 08:08 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,771 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
This thread will document my teardown and rebuild of a Chevy 350 small block engine.
This may be old hat to many of you, but I have never done it before and figured some of you may be interested as well, especially if you are considering putting one of these into your 914. The engine that I am starting with is a 4 bolt main block truck engine out of a 1985 Chevy K20 3/4 ton pickup. I am not yet sure what the engine will be when I am done with it. I want to build a 383 stroker engine. But, the parts for this engine are so nice that I may stick with stock displacement and just go with better heads and intake. The heads and intake have all the smog stuff on them, so they are not going to be used. Enough with words. Time for pictures. First, lay out your tools on the rear trunk of your old Porsche. Only the finest work jacket will do to keep the paint scratches to a minimum. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897321.1.jpg) For tear down you need 4 wrench sizes (all inch sizes). 3/8, 7/16, 9/16, and 5/8th. You will want to have these sizes in deep sockets and wrenches. You will want to have at least one breaker bar to break torque on most of the 9/16 and 5/8 bolts. Also a rubber hammer, pry bar, and scraper will be needed. The beast: (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897321.2.jpg) This is the engine that I am going to be tearing down. It was pulled out of the donor truck Dec 10th and mounted on the engine stand the next day. Don't even think of trying to do this without an engine stand. This 1000 pound stand only cost $50, and it is money well spent. Fair bet my 914 has a little bit of engine envy right now.... Valve covers first. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897322.3.jpg) Valve covers need to come off first, as they impinge removing the intake. One off in the picture above. You need a 7/16 deep socket to take off the nuts that hold the valve covers on. Lots of sealant was used here. Valve covers, carb and intake are off. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897323.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897324.5.jpg) Pretty easy so far. Time to go for the heads. The rods going into the block are all the push rods. They come up from the cam and operate the valves. The orange ball of fire is my heater. 70K BTU of warmth to stave off the cold, even with the garage door open. I even had to take off my warm overalls, as I started sweating with the heater and the overalls both. The intake was attached with 9/16th bolts. There was considerable sealant used, and getting the intake off was difficult. I ended up using a pry bar to get it started, and hold it up enough to get my fingers in there to pull the rest off. First head is off. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897325.6.jpg) This is the point where I had to do some soul searching. It was pristine! The cylinder walls look like they were just done. There was no carbon ring at the top of the cylinders, which is common for an engine with miles on it. The PO of the donor truck said the engine had been rebuilt 4000 miles ago. But given the condition of the truck and the electrical system (the spark plugs were rusted and fell apart on removal) I had my doubts. Now, though... it took a fair deal of will power to not just button the engine back up again and put new heads and intakes on it. But, I am a stubborn man at times... I am going to rebuild this engine, darn it! This is how I learn. The heads bolts were 5/8s and were heavily torqued. I needed a breaker bar to get them started. With the heads off I took off the pulley and damper. The damper was a PAIN to get off. Lots of prying with the pry bar all over to keep it from cocking. One of those things where I probably should have used a puller, but I did not have one the right size or the desire to go and get one. to be continued.... |
| VaccaRabite |
Dec 20 2010, 08:10 PM
The cam is still in the block. I have not yet figured out how to remove it. Pretty sure I need to pull the freeze plug at the back of the engine and slide out the cam. But aside from that and a few bits and bobs, the engine is now totally torn down, and I am ready to start cleaning the block.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897457.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897458.2.jpg) So, what’s next? Well, obviously, the cam needs to come out. However that works. Then I am going to pull all the freeze plugs and start cleaning out the galleries. Oil and sludge build up in the galleries and that can hurt the engine over time. CLEAN CLEAN CLEAN. Also, I am going to do some dressing on the block. Open up some oil drain holes, take off rough edges, and do other things to improve the qualities of the block. Then the block will go to my local machinist. I need to find out what size everything is, and let him run it through the hot tank. I am pretty sure the cylinders were cut to 30 over, and I do not think that they will need to be recut. I do want to see if the crank needs to be standard or over. That will affect bearings and what parts I get. I'll do the hone job when it gets back. Then clean it some more, and paint it. So thats all I have for today. I'll update the thread as more gets done. I have to say, it is very tempting to put this into the 914.... Especially if I build the 383. Zach |
| stewteral |
Dec 21 2010, 03:57 PM
Old Member ![]() ![]() Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
The cam is still in the block. I have not yet figured out how to remove it. Pretty sure I need to pull the freeze plug at the back of the engine and slide out the cam. But aside from that and a few bits and bobs, the engine is now totally torn down, and I am ready to start cleaning the block. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897457.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897458.2.jpg) So, what’s next? Well, obviously, the cam needs to come out. However that works. Then I am going to pull all the freeze plugs and start cleaning out the galleries. Oil and sludge build up in the galleries and that can hurt the engine over time. CLEAN CLEAN CLEAN. Also, I am going to do some dressing on the block. Open up some oil drain holes, take off rough edges, and do other things to improve the qualities of the block. Then the block will go to my local machinist. I need to find out what size everything is, and let him run it through the hot tank. I am pretty sure the cylinders were cut to 30 over, and I do not think that they will need to be recut. I do want to see if the crank needs to be standard or over. That will affect bearings and what parts I get. I'll do the hone job when it gets back. Then clean it some more, and paint it. So thats all I have for today. I'll update the thread as more gets done. I have to say, it is very tempting to put this into the 914.... Especially if I build the 383. Zach Hi Zach, I hate to be the Buzz-Kill here, but I would like to suggest taking a look at your whole power & drive train as a unit. From what I've tracked about conversion cars, if you plan to run the STOCK 901 trans, you have to look at about a 350 HP limit (and what ever torque the engine develops as this power level) or things will BREAK!! Next, take a look at the puny CV joints with only 4 bolts! Also, at this power level, you can keep your stock crank and rods. When I looked at building my conversion, I wanted to go BIG so I built a 500 HP 383, but I also had to cough up $2300 for a 930 trans and lucked into used 911 SC/Turbo half shafts for $80 (they fit the 914 hub bearings) and finished off with 911 wheel flanges. I've posted a lot of stuff on the Paddock forum on chassis, handling, engine cooling, etc. as it will take some work to get things to operating as an intregal package. Unless you plan on chasing down a 930 4-spd, or better, a G-50 5-spd (the Pantera 5spd also can be made to work), my recommendation is to build a nice 350, not bother with a 383 and use a low-end cam as a member suggested. Summit has small-port aluminum heads for something under $900, if that's in your budget. Small ports work great for low-end through mid-range operation along with the mild cam. Not only do aluminum heads look great, but you save 50 lbs off the top of the tall V8. Since the whole design of the chassis was based on a pancake motor, the heavy V8 really messes up the CG, causing much more roll than originally planned. The less tall weight the better. I hope I haven't spoiled your day, but a mild engine will give you a great running, reliable daily driver that gets decent mileage. My 383 gets only 13 MPG!!!! Best, Terry |
| messix |
Dec 21 2010, 04:28 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
The cam is still in the block. I have not yet figured out how to remove it. Pretty sure I need to pull the freeze plug at the back of the engine and slide out the cam. But aside from that and a few bits and bobs, the engine is now totally torn down, and I am ready to start cleaning the block. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897457.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-1435-1292897458.2.jpg) So, what’s next? Well, obviously, the cam needs to come out. However that works. Then I am going to pull all the freeze plugs and start cleaning out the galleries. Oil and sludge build up in the galleries and that can hurt the engine over time. CLEAN CLEAN CLEAN. Also, I am going to do some dressing on the block. Open up some oil drain holes, take off rough edges, and do other things to improve the qualities of the block. Then the block will go to my local machinist. I need to find out what size everything is, and let him run it through the hot tank. I am pretty sure the cylinders were cut to 30 over, and I do not think that they will need to be recut. I do want to see if the crank needs to be standard or over. That will affect bearings and what parts I get. I'll do the hone job when it gets back. Then clean it some more, and paint it. So thats all I have for today. I'll update the thread as more gets done. I have to say, it is very tempting to put this into the 914.... Especially if I build the 383. Zach Hi Zach, I hate to be the Buzz-Kill here, but I would like to suggest taking a look at your whole power & drive train as a unit. From what I've tracked about conversion cars, if you plan to run the STOCK 901 trans, you have to look at about a 350 HP limit (and what ever torque the engine develops as this power level) or things will BREAK!! Next, take a look at the puny CV joints with only 4 bolts! Also, at this power level, you can keep your stock crank and rods. When I looked at building my conversion, I wanted to go BIG so I built a 500 HP 383, but I also had to cough up $2300 for a 930 trans and lucked into used 911 SC/Turbo half shafts for $80 (they fit the 914 hub bearings) and finished off with 911 wheel flanges. I've posted a lot of stuff on the Paddock forum on chassis, handling, engine cooling, etc. as it will take some work to get things to operating as an intregal package. Unless you plan on chasing down a 930 4-spd, or better, a G-50 5-spd (the Pantera 5spd also can be made to work), my recommendation is to build a nice 350, not bother with a 383 and use a low-end cam as a member suggested. Summit has small-port aluminum heads for something under $900, if that's in your budget. Small ports work great for low-end through mid-range operation along with the mild cam. Not only do aluminum heads look great, but you save 50 lbs off the top of the tall V8. Since the whole design of the chassis was based on a pancake motor, the heavy V8 really messes up the CG, causing much more roll than originally planned. The less tall weight the better. I hope I haven't spoiled your day, but a mild engine will give you a great running, reliable daily driver that gets decent mileage. My 383 gets only 13 MPG!!!! Best, Terry ya kinda missed that he's not putting it into a 914! the picture of the old army truck is where the mouse will live. |
| SirAndy |
Dec 21 2010, 09:29 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,304 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have to say, it is very tempting to put this into the 914.... Especially if I build the 383. if you plan to run the STOCK 901 trans, you have to look at about a 350 HP limit (and what ever torque the engine develops as this power level) or things will BREAK!!Ya kinda missed that he did say he was tempted ... (IMG:style_emoticons/default/shades.gif) But knowing Zach's Jedi like powers when it comes to resisting temptation, it's probably safe to say you are right .... (IMG:style_emoticons/default/laugh.gif) |
Vacca Rabite The small block thread Dec 20 2010, 08:08 PM
Vacca Rabite Heads are off, and it’s time to remove the oil p... Dec 20 2010, 08:09 PM
scotty b 350's are junk. Get a 440 for that p.o.s. A 44... Dec 20 2010, 08:17 PM
hot_shoe914 I sure hope you had the factory spec Folgers coffe... Dec 20 2010, 10:18 PM
914.SBC
I sure hope you had the factory spec Folgers coff... Dec 20 2010, 10:35 PM
Gint A stock 350 bottom end rebuild with a decent cam a... Dec 20 2010, 10:54 PM
messix get a long bolt to thread into the cam and pull it... Dec 21 2010, 01:17 AM
Vacca Rabite
did you see the small plug on both sides of the b... Dec 21 2010, 07:40 AM
scotty b Before you go assuming you ned a line bore, clean ... Dec 21 2010, 07:43 AM
hot_shoe914 B)-->
Vacca Rabite Lets talk intake and cam.
I would like this engine... Dec 21 2010, 08:52 AM
ArtechnikA
I would like this engin... Dec 21 2010, 09:33 AM
Andyrew I have an RV cam in my engine, but its one of the ... Dec 21 2010, 10:13 AM
andys After some experience with the GEN III Chevy motor... Dec 21 2010, 11:12 AM
messix the 383 build reuses the rods.
a 383 kit has the ... Dec 21 2010, 11:30 AM
ArtechnikA
a mild 383 built right will have big block type t... Dec 21 2010, 11:47 AM
messix
a mild 383 built right will have big block type ... Dec 21 2010, 12:36 PM
ArtechnikA
well coming from some one that bought a ..... for... Dec 21 2010, 01:08 PM
andys
the ls motors are awesome but you loose the k.i... Dec 21 2010, 01:59 PM
Vacca Rabite I have to say I am not to worried about breaking p... Dec 21 2010, 09:19 PM
messix
I have to say I am not to worried about breaking ... Dec 21 2010, 10:21 PM
kg6dxn If it's going in a truck, I say go with the 38... Dec 21 2010, 09:32 PM
hot_shoe914 Completely stripped it is easily movable by one pe... Dec 21 2010, 09:34 PM
messix have you looked up the vortec heads? Dec 21 2010, 10:22 PM
Vacca Rabite
About 30 m... Dec 22 2010, 07:06 AM
scotty b Definitely worth looking for a set. The thing to n... Dec 22 2010, 07:08 AM
messix B)-->
Vacca Rabite Cams.
I have been reading on cam selection.
My bl... Dec 28 2010, 10:22 PM
messix with proper break in oil and the cam gets a moly g... Dec 28 2010, 11:11 PM
charliew After breakin use diesel motor oil it still has al... Dec 29 2010, 09:19 AM
Vacca Rabite I am nearly done stripping the block for the machi... Dec 29 2010, 03:09 PM
messix the machinist will remove the cam bearings.
it ta... Dec 29 2010, 03:23 PM
Vacca Rabite My 383 dreams have been killed.
A sizable stipend... Jan 8 2011, 07:16 PM
messix
A sizable stipen... Jan 8 2011, 07:41 PM
scotty b For what this is going in you really don't nee... Jan 8 2011, 07:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th August 2025 - 08:31 PM |
