My car refuses to shift into 2 gear, I have no clue were to start |
weird_looking_cactus |
Mar 19 2004, 10:18 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
When I had the car running and was able to drive it the car, it would not shift into second gear. It had a pushing filling on it when I would try to go into that gear. Also even though I have the clutch all the way in and changing gears like from reverse to first it would make a big grinding noise but only once in a while. So Im thinking I need to tighten my cable to stop the grinding noise. But I have no clue about how to fix second gear. My car is a 1975 2.0 with side shifter. Thanks for those who help.
rhodyguy |
Mar 28 2004, 11:56 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
there is a bushing in the firewall, one where the rod enters the bracket on the trans, the ball cup, and two in the shifter itself. order them all. as mentioned get them from independent vendors. when you put in the firewall and bracket bushings heat them up in some water in the microwave, not too much, they will go in much easier. if you look at the bottom of the shifter, the springs for the 1st- reverse lock out plate are probably coated with dirt and muck, so clean that up also. do the search for redbeards shift lingage/shifter install and adjustment(pelican also). very straight forward and it works.
kevin |
Lo-Fi Version | Time is now: 8th June 2024 - 04:21 PM |
