> trans mounts
mrbubblehead
post Dec 28 2010, 10:09 PM
Twodollardoug
what are my options to replace my rear trans mounts? my old ones are shot. it looks like the oem ones are nla. do the 911 ones need to be modified to make work? what about the WEVO 914 Semi-Solid Engine Mount, BLUE PILLOWS. are they worth the extra dough? are the blue pillows direct bolt ins?
post Dec 29 2010, 12:43 AM
Resident German
The 911 sport motor mounts can be used as a direct replacement for the 914 transmission mounts. Depending on your car you might have to oval out the mounting holes just a tiny bit.
Just make sure you reuse all of the hardware and washers, including the large cup-washer!
detoxcowboy
post Dec 29 2010, 12:35 PM
Region Association: Africa
QUOTE(SirAndy @ Dec 28 2010, 10:43 PM) *
(IMG:style_emoticons/default/agree.gif) very slight ovaling of the mounting holes, check how much before egging out..
above is 911 sport motor mount..
above is the factory 914 transmission mount. HTF but there is a pair of NOS on ebay at $99.99 each under search term Porsche 914 NOS.
both have rubber involved but the 911 style is stiffer and does not hang as far as the 914 factory Version..
mrbubblehead   trans mounts   Dec 28 2010, 10:09 PM
markb   There's a couple of different options. If you ...   Dec 28 2010, 10:22 PM
RJMII   the 911 units are direct bolt in. I've got tho...   Dec 28 2010, 10:56 PM
silver74insocal   i beleive the 911 engine mounts are exactly the sa...   Dec 28 2010, 10:59 PM
RJMII   i beleive the 911 engine mounts are exactly the s...   Dec 28 2010, 11:31 PM
RobW   Direct bolt up, but talk with GPR about what they ...   Dec 29 2010, 12:01 AM
mrbubblehead   Direct bolt up, but talk with GPR about what they...   Dec 29 2010, 12:11 AM
RJMII   911 ones are pretty good for a street car. I'v...   Dec 29 2010, 12:28 AM
mrbubblehead   911 ones are pretty good for a street car. I...   Dec 29 2010, 12:41 AM
SirAndy   The 911 sport motor mounts can be used as a direct...   Dec 29 2010, 12:43 AM
detoxcowboy   The 911 sport motor mounts can be used as a direc...   Dec 29 2010, 12:35 PM
mrbubblehead   im leaning towards the 911's. there cheaper, a...   Dec 29 2010, 12:48 AM
SirAndy   i think they'll be just fine. :agree: 5 ye...   Dec 29 2010, 01:00 AM
Derek Seymour   I dig my Tarrett solid rear mounts. IMHO it will...   Dec 29 2010, 02:15 AM
Joe Sharp   Hey Doug, I have the 911 sport mounts in the race ...   Dec 29 2010, 08:05 AM
sean_v8_914   solid mounts transfer noise, vibration and stress ...   Dec 29 2010, 09:10 AM
detoxcowboy   solid mounts transfer noise, vibration and stress...   Dec 29 2010, 12:37 PM
Root_Werks   solid mounts transfer noise, vibration and stres...   Dec 29 2010, 01:06 PM
underthetire   911 mounts on mine. Did have to just slightly slot...   Dec 29 2010, 11:29 AM
Root_Werks   The search function works well: http://www.914wor...   Dec 29 2010, 11:40 AM
- Lo-Fi Version Time is now: 11th July 2025 - 09:11 PM
