> Need to increase negative camber, track set up
sixaddict
post Dec 24 2010, 04:04 PM
Need to increase negative camber. What are best options up front and cost of what you did. Rear also. I am using car for both track and AX (likely to go A-6s) so some compromise involved. Winter project. For track going to be running RA1s (previously 888s). (IMG:style_emoticons/default/evilgrin.gif)
Words of wisdom please.
PlaysWithCars
post Dec 30 2010, 01:34 AM
If raising the outer swing arm mounting point as much as possible my removing all shims doesn't get you enough rear camber, is it possible to lower the inner swing arm mounting hole in the suspension console?
J P Stein
post Dec 30 2010, 05:49 AM
Irrelevant old fart
QUOTE(plays with cars @ Dec 29 2010, 11:34 PM) *
It's possible just bloody difficult. The pic doesn't do a good job of showing the raised portion around the SW flange, but it is there.
sixaddict
post Dec 30 2010, 02:52 PM
Sixnot four:
That is solution proposed to me and it makes me a little nervous. Does this solution "look" normal if done correctly? No issue with strength?
What about mounting tabs for sway bar.
THX
Terry
QUOTE(J P Stein @ Dec 30 2010, 03:49 AM) *
- Lo-Fi Version Time is now: 16th June 2024 - 09:52 PM
