Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
I got an email from CIP1 saying my previous order is now in stock. Is this the right bearing set - assuming it hasn't align bored and the crank is stock?
http://www2.cip1.com/ProductDetails.asp?Pr...2D198%2D481%2DA |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
I am awaiting a set of the Silverline mains to measure and critique when we return from our Holiday shutdown..
I made a detailed post on my forums about the my previous experiences with these silverline bearings.. Only time will tell if the bearings are in better than they used to be. The specs of these bearings are all over the place, excess bearing clearances, not enough clearance and the bearings weigh significantly less than any other on the market. Seldom when bore sizing the bearings they were seldom even close to being round. The previous quality of the silverline bearings was so horrible that I'd rather reuse old bearings as to use them in one of my engines.. I'd rather have no parts as junk parts. I'd recommend that anyone using any bearing that comes back on the market to approach the assembly and blueprinting with great care, despite who manufactures the bearings. The last word we heard from Mahle was if the bearings ever come back the center mains won't even be steel backed, which is something thats done for a really big reason. They did this to T1 bearing sets as well. My fear is someone saw a huge void in the market and did a run of these to make a quick buck and they threw QC out the window. Approach with great care.. FWIW- One day the companies that took advantage of this bearing situation will see just how much of a Bitch karma really is. This post has been edited by Jake Raby: Dec 30 2010, 08:07 PM |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
You are the authority with the last word to comment on these Jake, that is for sure. If YOU approve the silverline then we can all use them.
In the meantime, we have ONLY Porsche factory and VW factory bearings on the shelf that we too were taken advantage of because of the limited market. We have them though! I am awaiting a set of the Silverline mains to measure and critique when we return from our Holiday shutdown.. I made a detailed post on my forums about the my previous experiences with these silverline bearings.. Only time will tell if the bearings are in better than they used to be. The specs of these bearings are all over the place, excess bearing clearances, not enough clearance and the bearings weigh significantly less than any other on the market. Seldom when bore sizing the bearings they were seldom even close to being round. The previous quality of the silverline bearings was so horrible that I'd rather reuse old bearings as to use them in one of my engines.. I'd rather have no parts as junk parts. I'd recommend that anyone using any bearing that comes back on the market to approach the assembly and blueprinting with great care, despite who manufactures the bearings. The last word we heard from Mahle was if the bearings ever come back the center mains won't even be steel backed, which is something thats done for a really big reason. They did this to T1 bearing sets as well. My fear is someone saw a huge void in the market and did a run of these to make a quick buck and they threw QC out the window. Approach with great care.. FWIW- One day the companies that took advantage of this bearing situation will see just how much of a Bitch karma really is. |
Lo-Fi Version | Time is now: 6th July 2025 - 01:53 PM |
