oil cooler seals, small winter project |
914 shifter |
Jan 2 2011, 10:33 AM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
i am going to order a set of oil cooler seals from pelican.has anyone purchased these? pelican has an article on this subject/install.looks like a real pita, but i do believe i have a leak/drip in this area so i will order seals tomorrow.they are only $1 each i just want to be sure they are the best choice. assuming there is a choice. (IMG:style_emoticons/default/cheer.gif) happy new year!
realred914 |
Jan 2 2011, 10:53 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
i am going to order a set of oil cooler seals from pelican.has anyone purchased these? pelican has an article on this subject/install.looks like a real pita, but i do believe i have a leak/drip in this area so i will order seals tomorrow.they are only $1 each i just want to be sure they are the best choice. assuming there is a choice. (IMG:style_emoticons/default/cheer.gif) happy new year! make sure the leak is not from the oil pressure sendor, that often is a leak that appear to come from the cooler. the oil pressure sendor can fail at the seam between the metal housing and the plastic inner part. It is cheap and fast to fix this before the oil cooler seals. I have had more failures of the oil pressur esendor than the oil cooler seals. so check that out first. if you dont want to buy a new sendor et, simply use a pipe plug (1/8 inch NPT) in place of the sendor for a while and see if the leaks goes away, if it does, then the oil sendor was either loose or leaking at the seams. may you have a leak free year!!!! |
Lo-Fi Version | Time is now: 4th June 2024 - 04:52 PM |
