Friday, 5 September 2025
> how to break into the front trunk, when the release mechanism is not working
DanT
post Jan 2 2011, 04:22 PM
Going back to the Dark Side!
(IMG:style_emoticons/default/sad.gif)
so it there an easy way to do this without major surgery?
thanks (IMG:style_emoticons/default/blink.gif)
Elliot Cannon
post Jan 2 2011, 05:40 PM
Group: Retired Members
Squirt some lube into the release cable housing. Helps a lot.
DanT
post Jan 2 2011, 05:43 PM
QUOTE(Elliot Cannon @ Jan 2 2011, 04:40 PM) *
yes it does, and I had lubed the cable several months ago...I was pretty sure the latch was just not releasing completely and that was the case...now all the slack is removed and the latch is readjusted properly.
timofly
post Jan 2 2011, 07:42 PM
QUOTE(DanT @ Jan 2 2011, 06:43 PM) *
Also, be sure that the cable is secured at all the factory points. Too much flex will prevent you getting the leverage you need to open the mechanism. BTDT.
- Lo-Fi Version Time is now: 5th September 2025 - 12:28 AM
