| steeks |
Jan 2 2011, 08:30 PM
Newbie ![]() Group: Members Posts: 36 Joined: 25-October 10 From: Prescott Valley, Arizona Member No.: 12,310 Region Association: None |
Hello All, Just have a quick question, I have a 72 1.7, It has been unseasonably cold up here in northern Arizona. I took the opportunity while my car was tucked safely away in the garage due to the snow to make a few small repairs, speedometer cable and such, It was 20 degrees and wet outside but decided to go for a test rip around the block to see if my speedo was working. I think I felt a little clutch chatter under hard acceleration in 2nd gear, never did it before and I drive it all the time, but I have never driven it when it was this cold outside and It wasnt even warmed up. My question is if the extreme cold could cause the clutch to "chatter" alittle bit under hard accel? Any input would be welcomed, Thanks!
| steeks |
Jan 2 2011, 08:56 PM
I am not even sure that that is what it was, Hell, It may have been the a back tire cutting loose in the wet conditions with cold tires, I don't know. I drve this car all the time and have never had it chatter like that, only did it in second gear, on the throttle pretty hard in 2nd gear after the clutch was already fully engaged.
steeks Will my clutch chatter in the cold? Jan 2 2011, 08:30 PM
jd74914 I've driven my car unwarmed-up down to close t... Jan 2 2011, 08:39 PM
detoxcowboy
I've driven my car unwarmed-up down to close ... Jan 2 2011, 08:57 PM
9146986 40 or 50 degress isn't going to make that big ... Jan 3 2011, 08:18 AM
Root_Werks
40 or 50 degress isn't going to make that big... Jan 3 2011, 10:22 AM
Cap'n Krusty
40 or 50 degress isn't going to make that bi... Jan 3 2011, 10:58 AM
underthetire Just a flat spot on the tire from sitting in the c... Jan 3 2011, 12:11 PM
steeks Ok, went on a more extensive test drive today, I t... Jan 3 2011, 01:20 PM
steeks Nope, that wasnt it. Getting very annoyed. Jan 3 2011, 09:46 PM
detoxcowboy It is a chatter noise only? How is the clutch? Jan 3 2011, 10:26 PM
steeks It's really hard to describe, It sounds like s... Jan 4 2011, 09:11 AM
detoxcowboy 914 noises, yeah!, love the mystery.. Sometime... Jan 4 2011, 09:40 AM
underthetire :agree:
The friggen jack strap scared the crap ou... Jan 4 2011, 11:51 AM
realred914 hell, my teeth chatter when it gets that cold. bi... Jan 4 2011, 11:54 AM
Drums66
hell, my teeth chatter when it gets that cold. b... Jan 4 2011, 05:41 PM
underthetire Cause your rim is bent :D
I'm sorry, I saw y... Jan 4 2011, 05:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 10:24 PM |
