| ellisor3 |
Jan 1 2011, 07:30 PM
HPWhore ![]() ![]() ![]() Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I got a new carpet kit with the floor vinyl. Well I lost the pieces of vinyl. Could someone post a picture of the pieces installed so I can cut new pieces to install.
Thanks everyone. (IMG:style_emoticons/default/beer.gif) |
| detoxcowboy |
Jan 3 2011, 10:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Just an assist. I lost my orignals as well. If you take out your seats and center box you will see that there is really only so much material you can place there before you run into or under (carpet/seat rails ect.), and what is going to have to be cut around or made cut out for ( seat belts/ parking brake release button/ seat height notch thingys/ door on the rear of center tunnel ect.). Just meaure the length of the humps to the point where they start to where the intended vinyl would either go under your center box or be stoped by your fire wall/backpad. Then measure the width of the area of the hump itself (hump hieght on 2 sides and its width plus a little extra to run under the carpet and under seats). You will end up with 4 rectangles of vinyl ( guessing about 24" x 5") that of which 2 go in front of the seats and the other 2 go on the sides of center tunnel in between the passenger and drivers seats. Lay them out with glue, cut out for areas which will be obvious as mentioned above using a razor blade, and trim the excess....done!!
Or just buy the kit from Appearance and Performance, which is cut to length and width but still needs a little cutting out here and there.. |
ellisor3 Need a photo-floor vinyl installed Jan 1 2011, 07:30 PM
racerbvd
I got a new carpet kit with the floor vinyl. Well... Jan 1 2011, 09:33 PM
dr914@autoatlanta.com Do you mean the floor pan tar kit? There is an il... Jan 3 2011, 09:20 AM
ellisor3
Do you mean the floor pan tar kit? There is an i... Jan 3 2011, 09:41 AM
dr914@autoatlanta.com I finally woke up and recognized what you meant.
... Jan 3 2011, 10:14 AM
dem I found this link when I was searching about redoi... Jan 3 2011, 12:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th September 2026 - 07:42 AM |
