| KELTY360 |
Jan 5 2011, 01:43 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,186 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
I need to replace my + battery cable. It has a threaded lug on the terminal that holds some smaller wires. Haven't been able to find a cable with this feature so I need some advice on the best way to handle these connections. What are my options?
| detoxcowboy |
Jan 5 2011, 09:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
There are alot of choices for battery cable terminals, but you will have to make your own, usually buying a longer one than what your using and cutting off to lenght on terminal side you won't be using then install your chosen one, or if you have length on the one you have pictured, cut the head off, put another on if the rest of the cable is ok to you.. There are all kinds on line not just at your flaps or car audio installer.. ( gold plated, led digital voltage read out, and python stamped on it (IMG:style_emoticons/default/drooley.gif) )
while your at it you could re-do the red wire terminals too, they look at bit exposed and haggard.. there are more but here is a start linky.. http://www.jcwhitney.com/battery-cables-an.../c921j1s17.jcwx |
KELTY360 Battery cable replacement Jan 5 2011, 01:43 PM
dr914@autoatlanta.com WE have the correct one, either just the terminal ... Jan 5 2011, 01:48 PM
KELTY360
WE have the correct one, either just the terminal... Jan 5 2011, 01:52 PM
dr914@autoatlanta.com No not the lug like that but the original German c... Jan 5 2011, 02:07 PM
Tom_T Marc, I think Jeff Bowlsby does them along with hi... Jan 5 2011, 02:08 PM
KELTY360
Marc, I think Jeff Bowlsby does them along with h... Jan 5 2011, 02:12 PM
kconway
Marc, I think Jeff Bowlsby does them along with h... Jan 5 2011, 02:45 PM
dflesburg FLAPS. Jan 5 2011, 03:12 PM
jd74914
FLAPS.
:agree:
I got one just like George is d... Jan 6 2011, 05:46 PM
realred914 wonder if there was more than one type on stock 91... Jan 5 2011, 05:28 PM
KELTY360
wonder if there was more than one type on stock 9... Jan 5 2011, 05:42 PM
914Sixer The cable that is in the picture is no where close... Jan 5 2011, 08:30 PM
Drums66 ....Just get it from George at AA :confused:
( or... Jan 6 2011, 05:28 PM
detoxcowboy Member Jeff Bowlsby has the factory cable that you... Jan 6 2011, 05:51 PM
bandjoey Quick down and dirty easy. AutoZone Clamp. Bundl... Jan 6 2011, 10:25 PM
76-914 I separated mine out to improve future electrical ... Jan 7 2011, 10:58 AM
9146986 Here's what the factory used. I'd love to... Jan 7 2011, 12:28 PM
KELTY360 You guys have given me lots of good ideas. I found... Jan 7 2011, 08:27 PM
9146986 That's what I've been putting on the ones ... Jan 8 2011, 09:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 03:14 AM |
