> fibreglass experts
scotty b
post Jan 5 2011, 03:17 PM
rust free you say ?
I have to make a custom bumper for a car. I am familiar with the mold process but what I do not know is what type of expandable foam I should buy. I am planning to make a wooden box ( form) to pour the foam in, then attatch it to the car and start cutting and sanding to get the desired shape. What I need is something that will expand and still be closed cell enough to handle cutting, sanding and shaping, then can handle bondo being applied to get that oh so smooth ready to be painted, finished buck. (IMG:style_emoticons/default/wacko.gif)
scotty b
post Jan 5 2011, 09:08 PM
rust free you say ?
The sheets and particularly spray foam just isn;t going to cut it. I'm talking about a whole front bumper. That stuff may be great for a small project or a home doer, butI have to keep this within a reasonable budget. Surfboard blanks crossed my mind but the amount I would need would be $$$$ plus shipping got to be even more $$$$$$. I am looking for expandables because they are smaller to ship, they will fill a large box fairly quick and easily, and it looks so cool when it starts to grow (IMG:style_emoticons/default/smoke.gif) I'll check out the sites Paul and Jim posted (IMG:style_emoticons/default/smile.gif) Mike, I hadn;t thought about florist foam, I know I can get that locally in large chunks but will it hold up to the ibeglass resin ? A lot of foams will disolve. I will be making a female mold off of the buck, but will keep the buck just in case. If this turns out well I am going to try and sell them. Under wraps for now so dont ax (IMG:style_emoticons/default/shades.gif) not for a 914 though, but it is in la familia (IMG:style_emoticons/default/smile.gif)
URY914
post Jan 6 2011, 06:01 AM
(IMG:style_emoticons/default/sunglasses.gif)--><div class='quotetop'>QUOTE(scotty b @ Jan 5 2011, 08:08 PM) *</div><div class='quotemain'><!--quotec-->
The sheets and particularly spray foam just isn;t going to cut it. I'm talking about a whole front bumper. That stuff may be great for a small project or a home doer, butI have to keep this within a reasonable budget. Surfboard blanks crossed my mind but the amount I would need would be $$$$ plus shipping got to be even more $$$$$$. [/quote]
You're not going to find anything cheaper than foam sheet and the spray can foams. Here is a shot of a ricer that had his front bumper using the only stuff from Home Depot, so it can be done on the cheap. Fill in the voids with the spray foam and make your female mold. It will take some work to get the mold perfect.
buhs914
post Jan 6 2011, 09:49 AM
Not So Newbie
[quote name='URY914' date='Jan 6 2011, 05:01 AM' post='1414236']
[/quote]
I like that fancy holding device. As for the foam I would have to agree with using the pink stuff and just layering it to get the size you need. I've noticed that the florist foam stuff costs a little more per volume than the pink stuff..
scotty b   fibreglass experts   Jan 5 2011, 03:17 PM
underthetire   Tap plastics used to sell a resin foam, it was pre...   Jan 5 2011, 03:38 PM
Rod   Use polyurethane two-part foam, The foam from diy...   Jan 5 2011, 03:53 PM
jd74914   :agree: I don't have much experience, but if ...   Jan 5 2011, 04:16 PM
iamchappy   Have you considered using Styrofoam and shaping it...   Jan 5 2011, 04:30 PM
URY914   Try looking at some of the projects on here..... ...   Jan 5 2011, 05:09 PM
andys   Try looking at some of the projects on here..... ...   Jan 7 2011, 10:48 AM
RJMII   This place seems to have a lot of information. I d...   Jan 5 2011, 05:12 PM
kg6dxn   Order some surf board blanks :headbanger: There...   Jan 5 2011, 05:14 PM
URY914   I see the pink insulation boards that you can get ...   Jan 5 2011, 05:55 PM
stepuptotheMike   One of the shows I saw on TV used sheets of floris...   Jan 5 2011, 06:16 PM
URY914   The spray on foam seems to be used also... Befor...   Jan 5 2011, 06:18 PM
r_towle   Scotty, Use the simple spray foam and cover it en...   Jan 5 2011, 07:16 PM
mepstein   comes in 914 colors   Jan 5 2011, 08:23 PM
plays with cars   Use the pink stuff from Home Depot. You can rough...   Jan 5 2011, 08:44 PM
Dr Evil   I have used the spray foam. Cheap and easy, oh ya ...   Jan 5 2011, 09:07 PM
scotty b   The sheets and particularly spray foam just isn;t ...   Jan 5 2011, 09:08 PM
stepuptotheMike   B)--><div class='quotetop'>QUOTE...   Jan 5 2011, 10:26 PM
URY914   B)--><div class='quotetop'>QUOTE...   Jan 6 2011, 06:01 AM
buhs914   B)--><div class='quotetop'>QUOT...   Jan 6 2011, 09:49 AM
Dr Evil   Shhhh Yer phone is broke <_<   Jan 5 2011, 09:29 PM
URY914   Yes the green foam used by the flower folks will n...   Jan 5 2011, 09:41 PM
Phoenix-MN   This place has all the "glassing" suppli...   Jan 5 2011, 10:02 PM
Dr Evil   Plastic wrap can work as well, no?   Jan 5 2011, 10:35 PM
stepuptotheMike   Plastic wrap can work as well, no? that's fo...   Jan 5 2011, 10:39 PM
scotty b   Plastic wrap can work as well, no? that's f...   Jan 5 2011, 10:43 PM
scotty b   Plastic wrap can work as well, no? No, the final...   Jan 5 2011, 10:42 PM
Borderline   The polyester resin will eat up a lot of stuff and...   Jan 6 2011, 10:22 AM
r_towle   Florist foam, the green stuff, holds up to "s...   Jan 6 2011, 07:59 PM
Bartlett 914   Still, the cheapest way to go is pink foam for ...   Jan 7 2011, 09:39 AM
scotty b   O.K. I'm going to try the pink foam since it i...   Jan 6 2011, 08:23 PM
RJMII   Woo hoo!! Pics ROCK!!! :hea...   Jan 7 2011, 09:20 AM
76-914   Stay away from from the polyester resins; unless y...   Jan 7 2011, 10:20 AM
geniusanthony   The cafe racer board I frequent also swears by flo...   Jan 8 2011, 12:30 AM
GS Guy   I believe Blueovalz did his car using the florist ...   Jan 8 2011, 09:54 AM
- Lo-Fi Version Time is now: 16th April 2026 - 09:12 PM
