| pcar916 |
Jan 6 2011, 09:49 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
Post 1 of 6
Turns out there are a few folks that want to see this. This started as a tangent to the "Which Engine is best, 3.2 or 3.6L?" thread. There is a voluntary factory recall on many of the 1995 and 1996 3.6L engine wiring harness' because of a bad formulation in the insulation. It turns into a crusty mess and can cause all kinds of issues. In my case it was very bad missing when it rained and an increasingly bad idle. But in some cases folks have fried their alternators. If you had/have a new 993 then Porsche would have notified you based on your VIN, but in my case I just bought an engine so was never notified. Here's the culprit. ![]() Here's what happens at the alternator ![]() |
| RON S. |
Jan 7 2011, 12:35 PM
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Perry, BTDT with mine. It raised it's ugly almost from the minute I started my car for the first time after it was road worthy. When I tracked down the misfire I damned near set the car on fire when the Alternator wire ground out. It was a great thing I had more than 1 battery quick disconnect switches installed on the teener. replacing the factory harness was a snap, and I actually ended up with an extra one if anyone needs one. you'll sleep easier now that the old harness is in the trash. Ron |
pcar916 993/914 engine wirning harness replacement Jan 6 2011, 09:49 AM
pcar916 #2
An injector branch... no wonder it was missing... Jan 6 2011, 09:53 AM
pcar916 #3
Here's the main trunk. Lot's of ugline... Jan 6 2011, 09:57 AM
Jeff Bowlsby Merc Benz from 1993-95 had exactly the same issue,... Jan 6 2011, 11:37 AM
pcar916 #4
Assuming the position...
Finding out I have t... Jan 6 2011, 10:01 AM
pcar916 #5
Don't even have to loosen the belt, just t... Jan 6 2011, 10:07 AM
pcar916 #6
Now, to tidy up and look for any unattached... ... Jan 6 2011, 10:10 AM
Woody I've done bunches of those recalls. Good stuff... Jan 6 2011, 11:11 AM
pcar916 I heard that Merc had stiffed their customers with... Jan 6 2011, 03:56 PM
396 Very interesting..thank you for the education. Jan 6 2011, 08:27 PM
Cap'n Krusty Late 70s through early 90s Volvos had this problem... Jan 6 2011, 08:47 PM
hot_shoe914 I had a '93 MB 300E, mine was beginning to hav... Jan 7 2011, 10:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 09:26 PM |
