> Cleaning a /6 oil tank
RiqueMar
post Jan 7 2011, 12:29 AM
Enrique Allen Mar
I have this oil tank from a /6 thats going in my car, any recommendations on cleaning it? Can't sandblast it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1294381763.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1294381764.2.jpg)
Scott S
post Jan 7 2011, 10:17 AM
Small Member
Took mine to a local radiator shop - it came out great. All of the gunk is gone from the outside, as well as a good portion of the paint, but the copper was 100% intact. They checked it for leaks and then rinsed it and sprayed the inside with a thin oil to prevent any rusting prior to install. They told me to throw some cheap oil in it and really slosh it around, then drain it. I plan on doing this a few times prior to installing and using it.
ME733
post Jan 8 2011, 07:34 AM
QUOTE(Scott Schroeder @ Jan 7 2011, 11:17 AM) *
..............CAUTION......Radiator shops use Water soluable oil. It,s thin and will evaporate, leaving water in the tank which will cause rust to form. Do a finish cleaning process before you store the tank., not just when you plan to install it.
RiqueMar   Cleaning a /6 oil tank   Jan 7 2011, 12:29 AM
mepstein   Looks nice enough that you might not have to strip...   Jan 7 2011, 06:02 AM
Krieger   I'd be leary about sand getting left behind an...   Jan 7 2011, 09:25 AM
ME733   ....... I have done this, Remove all fittings. Tak...   Jan 7 2011, 09:58 AM
laflaur   I did the same as ME,except when I got to the end ...   Jan 7 2011, 10:02 AM
mepstein   I still have to clean mine out but once it's t...   Jan 7 2011, 10:14 AM
Scott Schroeder   Took mine to a local radiator shop - it came out g...   Jan 7 2011, 10:17 AM
ME733   Took mine to a local radiator shop - it came out ...   Jan 8 2011, 07:34 AM
rgalla9146   If you take it to a radiator place make sure they ...   Jan 7 2011, 10:29 AM
RiqueMar   Thanks for the response guys! I'm looking ...   Jan 7 2011, 11:31 AM
RiqueMar   Thanks for the responses guys! I'm lookin...   Jan 7 2011, 11:47 AM
mepstein   When I called around, I had the same challenge. Al...   Jan 7 2011, 12:08 PM
RiqueMar   When I called around, I had the same challenge. A...   Jan 7 2011, 12:11 PM
9146BRUCE   Hi try Pacific Oil Cooler Service thats where I se...   Jan 7 2011, 01:32 PM
mepstein   Hi try Pacific Oil Cooler Service thats where I s...   Jan 7 2011, 03:26 PM
9146BRUCE   I think it was about 175.00 cleaned and repainted.   Jan 7 2011, 03:41 PM
9146BRUCE   and pressure tested   Jan 7 2011, 03:42 PM
mepstein   Did they replate with copper?   Jan 7 2011, 03:47 PM
Al Meredith   I have not done an oil tank ,but I have taken two ...   Jan 7 2011, 06:13 PM
ME733   I have not done an oil tank ,but I have taken two...   Jan 8 2011, 07:28 AM
sww914   I did one a few months ago. It was $50.00 to...   Jan 8 2011, 05:17 PM
moparrob   Here is a quote I got from Pacific last August: ...   Jan 8 2011, 11:55 PM
- Lo-Fi Version Time is now: 24th May 2026 - 10:26 PM
