| porsche4me |
Jan 8 2011, 12:03 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 27-March 03 From: savannah Member No.: 483 Region Association: None |
Two basic wiring questions : Building a race car from an empty shell - not one single wire in the car !!
#1 -- How many and Where do the wires from the alternator go ?? this is a very basic race car - no fancy electronics - it has Carbs and a pertronix Distrib. #2 --- I have an Ignition switch next to a start button.... I know where the starter button wires go --- But where do I run the ignition "HOT" wire to and from ??? the + side of the coil - thru a fuse - to the + side of the battery ??? Thanks --- cant believe I could not find the answers to my dumb questions --- I guess I must be dumber than the normal race car builder ---- |
| Mike Bellis |
Jan 8 2011, 12:26 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Alternator charge wire goes to the battery. use #6 copper or bigger.
you will need to power the + side of the coil with you "hot while cranking" switch position. |
porsche4me Two basic wiring questions Jan 8 2011, 12:03 PM
type47 This might get you close to your answer:
http://w... Jan 8 2011, 12:24 PM
porsche4me thanks - sorry the body is a 76 ---- the motor i... Jan 8 2011, 12:32 PM
porsche4me Alternator charge wire goes to the battery. use #6... Jan 8 2011, 12:35 PM
kg6dxn
Alternator charge wire goes to the battery. use #... Jan 8 2011, 01:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 11:02 PM |
