> Fuse Covers, New pic's of finished version
76-914
post Jan 7 2011, 01:08 PM
First; thanks to Joe Sharpe and Saun Malloy for the effort to provide me with a panel, with which to practice. Second; fuses are placed at random and are not emblematic of a correct installation. Thirdly; this item is for CSOB's and not Pebble Beach. That being said, here is the first attempt. My goal is to provide you with info on "how to" make one of these in a few min's with materials that are free (already in your inventory) or quite cheap and the instructions to do so. Also, I want to develope two different methods for forming these. One using a heat gun and the other using your oven (in case you don't own a heat gun). I haven't got all the details down for the oven method complete but hope to have that completed in the next week. You will see that I have drilled 2 holes in the board 11mm apart to secure it. This spacing is used so you can use the existing 2 screws holding the fuse block if you don't want to drill your board. Either way, you will need a screwdriver to remove it in order to R&R a fuse. I'm pretty sure most of us carry a screwdriver in our 914, anyway. Will update this in the next few days.
Mike Bellis
post Jan 8 2011, 11:47 PM
Resident Electrician
It looks great but... If you blow a fuse on the road, you need a screwdriver to fix it. How about just some hook/loop attachment in lieu of the screws?
- Lo-Fi Version Time is now: 3rd March 2026 - 07:41 PM
