| 76-914 |
Jan 7 2011, 01:08 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,866 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
First; thanks to Joe Sharpe and Saun Malloy for the effort to provide me with a panel, with which to practice. Second; fuses are placed at random and are not emblematic of a correct installation. Thirdly; this item is for CSOB's and not Pebble Beach. That being said, here is the first attempt. My goal is to provide you with info on "how to" make one of these in a few min's with materials that are free (already in your inventory) or quite cheap and the instructions to do so. Also, I want to develope two different methods for forming these. One using a heat gun and the other using your oven (in case you don't own a heat gun). I haven't got all the details down for the oven method complete but hope to have that completed in the next week. You will see that I have drilled 2 holes in the board 11mm apart to secure it. This spacing is used so you can use the existing 2 screws holding the fuse block if you don't want to drill your board. Either way, you will need a screwdriver to remove it in order to R&R a fuse. I'm pretty sure most of us carry a screwdriver in our 914, anyway. Will update this in the next few days.
| RJMII |
Jan 9 2011, 02:10 PM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Kent, it's not necessarily that one might blow a fuse, but one might need to twist the fuse and get it to 'reseat' from corrosion/oxidization. I had that issue almost as much as kicking them out on entry of the vehicle.
76-914 Fuse Covers Jan 7 2011, 01:08 PM
dr914@autoatlanta.com Neat idea!!!! Has it been ... Jan 7 2011, 01:14 PM
Drums66 ....that looks like it has some promise.....eager ... Jan 7 2011, 02:44 PM
flipb :clap:
Fantastic!
My fuse cover was cracked ... Jan 7 2011, 02:49 PM
rfuerst911sc Maybe velcro ? Jan 7 2011, 03:00 PM
zonedoubt ...or you can just buy the cheap VW one which fits... Jan 7 2011, 03:02 PM
76-914 So here are a few shots of a finished cover. The j... Jan 8 2011, 08:02 PM
kg6dxn It looks great but... If you blow a fuse on the ro... Jan 8 2011, 11:47 PM
RJMII
It looks great but... If you blow a fuse on the r... Jan 9 2011, 09:12 AM
76-914
It looks great but... If you blow a fuse on the r... Jan 9 2011, 10:05 AM
silver74insocal :trophy: lookin good Kent.. Jan 9 2011, 12:04 AM
kg6dxn How about some self adhesive magnetic strip on the... Jan 9 2011, 02:39 PM
76-914
How about some self adhesive magnetic strip on th... Jan 10 2011, 09:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 07:40 PM |
