quadracerx |
Member ![]() ![]() Group: Members Posts: 428 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest ![]() |
My 76 Red car got converted to dual Webers before I bought it...Since ive owned it, it has always had a VERY strong fuel smell after running it for awhile....It has the expansion tank still on it. If it sits for a couple days no smell....checked lines and tunnel and no visible leaks...no leaks under car....Im stumped...
HELP the smell is so bad that it lingers long after shutting the car down......It even makes my clothes smell just from running the car... Thanks again, everyone (IMG:style_emoticons/default/beerchug.gif) Steve |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Below is the fuel evaporation lines at the engine compartment TOM was ititerating..
They come in behind and below the relay board from your charcoal cannister via the drivers side rocker panel, and there are cloth hose connections in the drivers front wheel well by the antenna and in the rocker panel that are made of cloth covver hose.. Usaally hard as a rock by now, unless you have replaced them.. The rest are vac hoses.. ![]() |
quadracerx |
Below is the fuel evaporation lines at the engine compartment TOM was ititerating.. They come in behind and below the relay board from your charcoal cannister via the drivers side rocker panel, and there are cloth hose connections in the drivers front wheel well and in the rocker panel that are made of cloth covver hose.. Usaally hard as a rock by now, unless you have replaced them.. The rest are vac hoses.. ![]() Cant I just block off the "green hoses" since I have carbs? I appologize if I sound stupid about this.... Steve |
Lo-Fi Version | Time is now: 1st July 2025 - 06:36 PM |
