| tornik550 |
Jan 9 2011, 10:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I decided earlier today to use a bus case for my rebuild. I had it laying around, it is a very nice case. I started to take the oil galley plugs out just like I have several times before on 914 cases. I ran into an issue that I hadn't on previous cases.
On the galley plug behind cylinder #1 near the flywheel side, there is a metal tube that runs from the rear cam bearing to the mechanical fuel pump boss. The tube blocks the galley and makes it so I cannot tap the hole. Since I am not running a mechanical fuel pump, can I just drill through the metal tube so that I can tap the galley hole? Attached image(s)
| Jake Raby |
Jan 10 2011, 08:37 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
You should have read my article before you started. That plug didn't need to be removed since uts a fuel pump case.
As Mark states, yu'll have to tap both sides of this galley, else you'll have no oil pressure! |
tornik550 Oil Galley- Bus Case Issue Jan 9 2011, 10:16 PM
bam914 You will need to remove the bronze bushing and tap... Jan 9 2011, 10:48 PM
Mark Henry You can just punch the tube out. You have to tap a... Jan 10 2011, 07:41 AM
tornik550
You should have read my article before you starte... Jan 10 2011, 08:55 AM
mrbubblehead
You should have read my article before you starte... Jan 10 2011, 09:23 AM
Jake Raby All my articles are on my forums.
Not all bus cas... Jan 10 2011, 10:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 07:51 PM |
