| stugray |
Jan 10 2011, 06:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Years ago, I needed to replace the bearings on either my Ghia or 914, and the VW dealer wanted an arm & leg for OEM.
I took the part number from the bearing and called a local bearing specialty house in Denver, and they had the exact same part for less than 1/4 of what the dealer wanted. Anyone know a cross ref. part number for rear wheel bearings? How about the dozens of bearings on ebay? Any good? Any ideas for the best deal? Oh, and what is the deal with the rear bearing seals? The manual states that if these are damaged, the entire trailing arm needs to be replaced... While I'm at it. Both arms are off and I am cleaning them up. What does everyone suggest I do while I have them off? I plan on painting them, but what else should I do while I'm at it? I have the welder at the ready, so I could do some reinforcing too. Stu |
| stugray |
Jan 10 2011, 12:20 PM
"513106"
Now that's what I'm talking about! Found them for $20 each! Thanks! I could probably find them at an industrial supply even cheaper, but they cannot cross-reference the number above. Any chance there is another number like NA107464 or something similar? If I remember they were only ~$10 ea last time, but that was almost 20 years ago. Here is another bearing related question: The bearings feel fine and turn very smoothly out of the car. However since I want to cleanup & strengthen the arms, I needed to break them all the way down. I knocked the spindles out using a 30mm socket and a hammer since I was planning on replacing the bearings anyway. Does this damage the bearings ( as opposed to pressing them out )? ....should I just reuse them for now? Stu |
stugray Anyone know the generic part # for rear wheel bearings? Jan 10 2011, 06:52 AM
type47 don't know cross reference but PET shows 999.0... Jan 10 2011, 07:06 AM
914Sixer There are no rear bearing seals. You may be confu... Jan 10 2011, 07:11 AM
mepstein Eric Shea- www.PMBPerformance.com Jan 10 2011, 07:29 AM
dr914@autoatlanta.com 443 407 625 is another number. We have several di... Jan 10 2011, 10:08 AM
andys 513106 is the generic number for the 914 rear whee... Jan 10 2011, 11:07 AM
Cap'n Krusty It destroys the bearings. No way would I install ... Jan 10 2011, 12:58 PM
andys
It destroys the bearings. No way would I install... Jan 10 2011, 05:03 PM
rohar I'm with the Cap'n. Of all the maintainan... Jan 10 2011, 01:21 PM
stugray Cap'n,
Could you explain the "chill and ... Jan 10 2011, 01:54 PM
Cap'n,
Could you explain the "chill and... Jan 10 2011, 02:02 PM
draganc
Cap'n,
Could you explain the "chill an... Jan 10 2011, 08:09 PM
Mark Henry I don't know how accurate this list is, but he... Jan 10 2011, 02:59 PM
SLITS
I don't know how accurate this list is, but h... Jan 10 2011, 06:37 PM
sww914 I have a pair of SKF in boxes on my desk. The 999 ... Jan 10 2011, 10:30 PM
Eric_Shea 545495AD
The 999 numbers are insaine. That's... Jan 11 2011, 10:09 AM
Hans Zupp 545495AD
The 999 numbers are insaine. That's... Jan 11 2011, 05:28 PM
stugray Funny,
Now that the part number above (545495AD) ... Jan 12 2011, 06:31 AM
rohar
Any opinions on what I should do to the arms whi... Jan 12 2011, 10:03 AM
tradisrad It's a good time to replace the bushings. How ... Jan 12 2011, 09:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 06:53 AM |
