| stugray |
Jan 10 2011, 06:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Years ago, I needed to replace the bearings on either my Ghia or 914, and the VW dealer wanted an arm & leg for OEM.
I took the part number from the bearing and called a local bearing specialty house in Denver, and they had the exact same part for less than 1/4 of what the dealer wanted. Anyone know a cross ref. part number for rear wheel bearings? How about the dozens of bearings on ebay? Any good? Any ideas for the best deal? Oh, and what is the deal with the rear bearing seals? The manual states that if these are damaged, the entire trailing arm needs to be replaced... While I'm at it. Both arms are off and I am cleaning them up. What does everyone suggest I do while I have them off? I plan on painting them, but what else should I do while I'm at it? I have the welder at the ready, so I could do some reinforcing too. Stu |
| stugray |
Jan 10 2011, 01:54 PM
Cap'n,
Could you explain the "chill and drop" method? Is just putting it in my freezer overnight good enough? Or Dry Ice ( or I could take all the parts to work with me and use liquid nitrogen ;-) I am used to heating things up to get them together, but obviously we dont want to heat the bearing enough for that to work. I would just press them in with my vise, but I dont think the jaws open enough with the bearing installed in the arm already. Looks like I'll just order them from www.PMBPerformance.com, but I want to inspect the CV joints first (didnt get that far last night) before I place the order. Stu |
stugray Anyone know the generic part # for rear wheel bearings? Jan 10 2011, 06:52 AM
type47 don't know cross reference but PET shows 999.0... Jan 10 2011, 07:06 AM
914Sixer There are no rear bearing seals. You may be confu... Jan 10 2011, 07:11 AM
mepstein Eric Shea- www.PMBPerformance.com Jan 10 2011, 07:29 AM
dr914@autoatlanta.com 443 407 625 is another number. We have several di... Jan 10 2011, 10:08 AM
andys 513106 is the generic number for the 914 rear whee... Jan 10 2011, 11:07 AM
stugray "513106"
Now that's what I'm ta... Jan 10 2011, 12:20 PM
Cap'n Krusty It destroys the bearings. No way would I install ... Jan 10 2011, 12:58 PM
andys
It destroys the bearings. No way would I install... Jan 10 2011, 05:03 PM
rohar I'm with the Cap'n. Of all the maintainan... Jan 10 2011, 01:21 PM
Cap'n,
Could you explain the "chill and... Jan 10 2011, 02:02 PM
draganc
Cap'n,
Could you explain the "chill an... Jan 10 2011, 08:09 PM
Mark Henry I don't know how accurate this list is, but he... Jan 10 2011, 02:59 PM
SLITS
I don't know how accurate this list is, but h... Jan 10 2011, 06:37 PM
sww914 I have a pair of SKF in boxes on my desk. The 999 ... Jan 10 2011, 10:30 PM
Eric_Shea 545495AD
The 999 numbers are insaine. That's... Jan 11 2011, 10:09 AM
Hans Zupp 545495AD
The 999 numbers are insaine. That's... Jan 11 2011, 05:28 PM
stugray Funny,
Now that the part number above (545495AD) ... Jan 12 2011, 06:31 AM
rohar
Any opinions on what I should do to the arms whi... Jan 12 2011, 10:03 AM
tradisrad It's a good time to replace the bushings. How ... Jan 12 2011, 09:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 06:54 AM |
