> Marker lights, electrical TS
mrgjones
post Jan 8 2011, 08:46 PM
Howdy y'all,
Left rear blinker is not cooperating. All others are just peachy. Switched relays (left and right) with same result. Any help would be lovely.
detoxcowboy
post Jan 8 2011, 10:57 PM
Region Association: Africa
?what year car? front blinker or rear? what does not cooperating mean exactly? not trying to be a dick, just need more info to assist.. there is only one turn signal relay in the fuse box panel, you may have been switching the headlight motor relays in the front trunk? check your bulbs first, try the hazards does it flash then?
mrgjones
post Jan 10 2011, 09:25 PM
QUOTE(detoxcowboy @ Jan 8 2011, 08:57 PM) *
74 rear, drivers side blinker. Not cooperating means there is no response from that that light when I flip the switch on the column. The relays I'm talking about are the two, round relays inboard on the back side of the fuse panel inside the cabin. Actually got the light to come on by cleaning up some corrosion but now it stays on any time the key is on.
- Lo-Fi Version Time is now: 7th December 2025 - 07:48 PM
