> Does this Flywheel picture give any reasons for concern?
Scott S
post Jan 11 2011, 10:46 AM
Small Member
Hi All –
I am in the final throws of my conversion. At this point the tub is done and everything is bolt on. The only part that is not easily accessible/changeable without big headaches is the flywheel/clutch, so I want to make sure I don’t bugger this up. Attached is a picture of a flywheel that I located on another web board. I was told it is original, worked fine, and was only removed because of a motor upgrade. The last clutch I personally replaced was in my 1985 GTI, so my knowledge is limited to say the least (the VERY least!!). Can any of you tell by this picture if this looks okay? I would have it machined prior to install, is there a minimum thickness I should ask the seller to verify?
Thanks a ton –
Scott S
zymurgist
post Jan 11 2011, 11:17 AM
"Ace" Mechanic
I would want to see the surface that rides against the oil seal.
- Lo-Fi Version Time is now: 17th April 2026 - 04:51 PM
