| Scott S |
Jan 11 2011, 10:46 AM
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All –
I am in the final throws of my conversion. At this point the tub is done and everything is bolt on. The only part that is not easily accessible/changeable without big headaches is the flywheel/clutch, so I want to make sure I don’t bugger this up. Attached is a picture of a flywheel that I located on another web board. I was told it is original, worked fine, and was only removed because of a motor upgrade. The last clutch I personally replaced was in my 1985 GTI, so my knowledge is limited to say the least (the VERY least!!). Can any of you tell by this picture if this looks okay? I would have it machined prior to install, is there a minimum thickness I should ask the seller to verify? Thanks a ton – Scott S Attached image(s)
| underthetire |
Jan 11 2011, 12:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Ya, it's missing a ring gear !
| Scott S |
Jan 11 2011, 12:13 PM
Ya, it's missing a ring gear ! Holy crap - I think you are right!!!! I can just cut some teeth onto it with a dremel cant I? (IMG:style_emoticons/default/headbang.gif) Oh well, the search continues........ Perry, just saw your email - thanks for the info! THANKS ALL!! (IMG:style_emoticons/default/beerchug.gif) |
Scott Schroeder Does this Flywheel picture give any reasons for concern? Jan 11 2011, 10:46 AM
Jeffs9146 Need close-up of the surface! Are there cracks... Jan 11 2011, 10:58 AM
realred914 cant tell in detail, but maybe just scuff up the r... Jan 11 2011, 11:15 AM
zymurgist I would want to see the surface that rides against... Jan 11 2011, 11:17 AM
9146986 Hard to tell from the pics, it looks flat, which i... Jan 11 2011, 11:58 AM
KELTY360
Holy cr... Jan 11 2011, 12:16 PM
SLITS That is nothing but the flywheel off a '70 ... Jan 11 2011, 12:38 PM
Scott Schroeder Thanks Ron... :beer1:
Does anyone have any exper... Jan 11 2011, 01:16 PM
SLITS You should be able to find an early 901, used, for... Jan 11 2011, 01:27 PM
sixnotfour I have a good 901 6bolt lightened to 9-10 lbs, goo... Jan 11 2011, 04:07 PM
SLITS
I have a good 901 6bolt lightened to 9-10 lbs, go... Jan 11 2011, 06:40 PM
Eddie914 MMMMMMMMMMMM! Must be some FABULOUS cheesburg... Jan 11 2011, 04:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 04:51 PM |
