> Starter Relay (Factory Styled) w/ Install Pics
detoxcowboy
post Jan 12 2011, 12:33 PM
Region Association: Africa
I made this relay for the starter using a 914 headlight relay mount. This should amplify the voltage at the soleniod by avoiding the voltage drop from the igniton switch. Also embedded in the wiring is a rectifier diode in line with the igniton switch/starter key to protect the ignition switch from the 350V EMF pulse comming from the starter solenoid when the current collapses.. (link to article below...see bottom of page).
Linky-
http://www.pelicanparts.com/techarticles/m...tarter_diag.htm
** side note,** I do not have a starting problem, in fact I ripped out the Bosch Hard Cure when I got the car so I could ensure proper function as per desighn, but I have had to switch out a relatively new ingnition switch (a year old or less) that left me with out warning stranded at a liquor store. Also when I was in below freezing/snow temps my Optima Battery was dying and before I figured that issue out, I tried applying 12 volts directly from the battery to the solenoid and definately noticed an immeadiate improvement in its desire to start even form a dying battery that could not hold a full charge any longer.
I usually do not share my 914 (%$& alternative ideas but thought using this set up would allow me to use the 914 round relays and also install a starter relay mounted in the engine compartment rather than the......dangling open environment the Bosch Hard Start Cure seems to be installed more often than not..
total cost a few dollars.. Anyways just a thought I thought I would put out there.
detoxcowboy
post Jan 13 2011, 11:52 PM
So far it works great, I am not having any proiblems and drive every day..
Unfortunately, I has received several pm regarding my use of a rectifier diode as improper, though have been told it was wrong either and I do not want to mis-led anybody..
It is working though; I think there is a mis-understanding somwhere and I do not want to cause anyone any issues or problems.
This was my first share of an idea, I tested everything.
>>> update; turns out my why correct in acheiveing what I was doing.,. this is just lost, sorry for deleting all the directions, and that is what happens when you think the other person is more knowledgebale than you..
detoxcowboy   Starter Relay (Factory Styled) w/ Install Pics   Jan 12 2011, 12:33 PM
dr914@autoatlanta.com   very nice factory looking piece! I am sure th...   Jan 12 2011, 12:42 PM
SirAndy   very nice factory looking piece! I am sure th...   Jan 12 2011, 12:46 PM
KELTY360   Nice looking solution Cowboy. Where are you mounti...   Jan 12 2011, 02:56 PM
detoxcowboy   ]   Jan 12 2011, 04:21 PM
detoxcowboy   RE: Starter Relay (Factory Styled) w/ Install Pics   Jan 12 2011, 04:26 PM
detoxcowboy   :D   Jan 12 2011, 04:42 PM
underthetire   Looks very nice. Just a side thought, I wonder if ...   Jan 12 2011, 05:38 PM
detoxcowboy   Looks very nice. Just a side thought, I wonder if...   Jan 12 2011, 06:14 PM
Spoke   You would want to mount the relay as close to the ...   Jan 13 2011, 07:51 AM
detoxcowboy   You would want to mount the relay as close to the...   Jan 13 2011, 08:27 AM
SLITS   I use a "Ford" style solenoid hung near ...   Jan 13 2011, 07:58 AM
zonedoubt   I use a "Ford" style solenoid hung near...   Jan 13 2011, 03:01 PM
markb   I use a "Ford" style solenoid hung nea...   Jan 14 2011, 12:18 AM
detoxcowboy   RE: Starter Relay (Factory Styled) w/ Install Pics   Jan 13 2011, 11:38 AM
Tom   Detox, Darn you, now I have no reason not to g...   Jan 13 2011, 11:55 AM
detoxcowboy   Detox, Darn you, now I have no reason not to ...   Jan 13 2011, 12:15 PM
detoxcowboy   RE: Starter Relay (Factory Styled) w/ Install Pics   Jan 13 2011, 01:15 PM
detoxcowboy   So far it works great, I am not having any proible...   Jan 13 2011, 11:52 PM
76-914   Me 4   Jan 14 2011, 09:59 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:56 PM
