| karlo |
Nov 21 2010, 10:16 PM
Karl Anders Øygard ![]() ![]() Group: Members Posts: 56 Joined: 2-November 09 From: San Diego, CA Member No.: 10,999 Region Association: Southern California |
Hi all!
Real short introduction. I'm on a three month leave here in San Diego, with my wife and 3 month old daughter. I live in Norway, but my American wife has family here, and winter is a great time to visit. It gets cold in Norway... I have a BMW 635CSi and a Citroen SM in Norway, but that's a different topic altogether. On to business. I have a 1974 914 (4742921095) that has been an AX car for the last ten years. My plan is to make the car more presentable--when I got it, it was quite rough. It's an SBC V8 build with a 915 transaxle and various 911 suspension parts. More about that later. The car doesn't look so good right now, in particular I don't like the flares, so I'm going to do a fairly thorough restoration. Not too much rust on the car, but it probably needs dealing with anyways. Here's the beauty: (IMG:http://www.914world.com/bbs2/uploads_offsite/people.opera.com-10999-1290399407.1.JPG) I bought this car from nocones last year, and it's been sitting for most of that time, due to a broken transmission (and also I've been back in Norway). During some fairly normal driving, it popped out of third gear and self destructed. I wasn't in the car at the time, so I'm not really sure what happened. Only inspection will tell. So, out the trans comes. ![]() Unscrewed the drain plug. This does not bode well: ![]() More carnage is visible once the nosecone is off: ![]() I need bigger tools to get the fifth gear and reverse off, so I can't get to the innards where the real action is right now. Will investigate that tomorrow. I found parts of what I suspect is a grenaded second gear. It remains to be seen whether the transmission is a lost cause. Input is appreciated. Maybe I should just get a 930 and be done with it... More tomorrow. - Karl |
| sean_v8_914 |
Jan 17 2011, 11:42 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
grinding, cleaning, cutting...
karlo karlo's 914 V8 adventures Nov 21 2010, 10:16 PM
sean_v8_914 Jackque at scotts porsche has a donor 915 for part... Nov 21 2010, 10:34 PM
karlo Yep, located at Rancho Peñasquitos. Maybe I'l... Nov 21 2010, 10:46 PM
karlo Got hold of some bigger tools, and pulled off 5th ... Nov 22 2010, 11:06 PM
karlo Caught a cold today, so nothing of interest happen... Nov 23 2010, 04:26 PM
Dr Evil Your slider is worn, that is why it popped out mos... Nov 23 2010, 04:48 PM
karlo Thanks for the insight. That's what I'm th... Nov 23 2010, 05:03 PM
karlo The Oceanside lead turned up empty, so no help the... Nov 24 2010, 10:48 PM
karlo Digging into rust issues while I'm considering... Nov 29 2010, 10:10 PM
SirAndy The driver's side hell hole has had standing w... Nov 30 2010, 12:41 AM
karlo
There are actually two plastic plugs, one larger ... Nov 30 2010, 07:35 PM
brilliantrot I would also suggest that you replace the main sha... Nov 30 2010, 12:38 AM
karlo Pictures of the hell holes, as promised, treated a... Nov 30 2010, 09:20 PM
karlo Rust removal continues. Have been derusting the he... Dec 15 2010, 09:44 PM
sean_v8_914 ...and the vertical wall (inner wheel house)behind... Dec 16 2010, 08:16 AM
sean_v8_914 snap a photo of the seam under teh hell hole. the ... Dec 16 2010, 08:25 AM
karlo Got a better picture of the underside of the LHS l... Dec 16 2010, 01:28 PM
sean_v8_914 viva la plasma cutter Dec 16 2010, 10:56 PM
karlo Sounds like I need to pay you a visit. :)
Need to... Dec 16 2010, 11:36 PM
sean_v8_914 it is MUCH better to do the chassis work while the... Dec 17 2010, 08:31 AM
sean_v8_914 exp Dec 17 2010, 08:34 AM
sean_v8_914 I like this one too but doesnt show area of discus... Dec 17 2010, 08:36 AM
sean_v8_914 since we are talking about messed up chassis...cen... Dec 17 2010, 08:37 AM
roadster fan This is not the best pic but may be helpful
Jim Dec 18 2010, 05:13 PM
karlo
Ji... Dec 18 2010, 07:07 PM
sean_v8_914 thank you. that view shows the two different layer... Dec 19 2010, 08:38 AM
karlo The car has found its way to Sean's shop where... Jan 8 2011, 02:51 AM
sean_v8_914 assemble and run it till it spits chuncks Jan 8 2011, 09:27 AM
sean_v8_914 compared to others, this chassis is fairly solid. ... Jan 22 2011, 11:02 AM
sean_v8_914 the rust seems to weaken the spot welds. then they... Jan 22 2011, 11:09 AM
sean_v8_914 My friend Bruce Stone, known here as the Porsche p... Jan 22 2011, 11:24 AM
sean_v8_914 this might be overkill but Im playing with it
htt... Jan 22 2011, 11:39 AM
sean_v8_914 the images with "sm" at the end of the n... Jan 22 2011, 11:40 AM
karlo While the car is in for welding, I've been wor... Jan 25 2011, 03:34 AM
sean_v8_914 that stupid crack by the E brake made me chase it ... Jan 25 2011, 08:21 AM
Dr Evil
good thing I can still hold my breath for about 2... Jan 25 2011, 09:16 AM
sean_v8_914 (tax payer financed) Navy training to hold breath ... Jan 25 2011, 09:34 AM
Dr Evil As a Yeoman? Are you still BSing people about your... Jan 25 2011, 10:08 AM
kg6dxn F-ing Squids... :poke: SEMPER FI :beer2: Jan 25 2011, 10:38 PM
sean_v8_914 no, actually I was a nurse in the coast guard Jan 26 2011, 01:35 AM
sean_v8_914 for some odd reason the chassis rail from teh rt s... Jan 26 2011, 01:51 AM
sean_v8_914 my harbour freight stud welder died so I welded on... Jan 26 2011, 01:54 AM
76-914 The Navy was created so Marines would have someone... Jan 26 2011, 09:03 AM
sean_v8_914 Marines were the onboard security force of the Nav... Jan 26 2011, 11:25 AM
914.SBC
Marines were the onboard security force of the Na... Jan 26 2011, 03:34 PM
sean_v8_914 the coolign system is early Renegade fro when they... Jan 26 2011, 05:13 PM
karlo 345 hp @ 5200, 387 lb-ft @ 3250. The carb setup re... Jan 26 2011, 11:08 PM
sean_v8_914 those Edlebrock carbs are about $250 new and ... Jan 26 2011, 11:24 PM
karlo Good tip. I'd have to learn something about ca... Jan 27 2011, 02:39 AM
karlo Some updates I got from Sean:
The usual crack in ... Feb 5 2011, 09:59 PM
sean_v8_914 here's an ugly one. I cant find the pic from u... Feb 6 2011, 12:07 PM
karlo More pictures from Sean:
Acid etched, rust passiv... Feb 12 2011, 02:56 AM
karlo Next in line is welding in steel flares, full repa... Feb 12 2011, 03:25 AM
karlo More updates from Sean:
Stealth GT.
Too dark t... Feb 18 2011, 11:45 PM
karlo SEM epoxy seam sealed, wurth etching primer, wurth... Feb 19 2011, 12:13 AM
karlo Further issues with the 911 ebrake setup. The ebr... Feb 20 2011, 11:34 AM
karlo The ring and pinion was in excellent shape, so was... Feb 20 2011, 12:26 PM
sean_v8_914 more quaiffe photos please so we can all drool and... Feb 21 2011, 10:55 AM
abnrdo Very nice! I am interested in how your body ... Feb 21 2011, 11:36 AM
karlo I forget the specifics, but Sean can probably fill... Feb 21 2011, 02:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 05:55 AM |
