| nsr-jamie |
Jan 16 2011, 09:44 PM
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Hi, just about to pull apart my entire suspension for the big winter project...I have all my suspensions parts ready to go (Koni shocks,Tarret 19mm front bar and 150 pound springs).... the last part I want to replace is the suspension bushings....what I am asking here is what is everybody using for their cars? My car will be a high performance weekend fun car, occasionally driven to work on nice days, mostly weekend mountain driving and occasional autocrossing...looking for a nice sporty ride.
I know Weltmeister makes a complete kit that Automotion sells for around 70 dollars for the set....than I noticed Tangerine has their sets too, and I always hear good things about the Elephant Racing bushings.....I was thinking about going with the Elephant bushings but they are expensive. Is installing the bushings a major job? I have never done this kind of work before...if any body has any advice or some suggestions or other bushings please feel free to post and thank you Cheers (IMG:style_emoticons/default/beerchug.gif) |
| pcar916 |
Jan 17 2011, 09:09 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
It's a matter of proper handling under heavy turns and severe braking and what that's worth to you. Much of that is related to the stiffness in your spring system, but if we assume the same spring rates in each case, I look at it as an easy decision. Only those I have experience with are listed.
The ones you can do yourself: 1. Stock: more deflection, thus more alignment changes during maneuvers. 2. Delrin: Cheap and very stiff but fine if properly installed. They wear out quickest of all of them. 3. Elephant Polybronze: Fairly easy installation, tiny deflection under stress. They're expensive but possibly the last ones the car needs if they are maintained (lubricated) properly. Professionally installed into your suspension arms, 1. Roller bearings: Most expensive, essentially no deflection, bolt-up installation by you. Prone to water intrusion if the seals aren't properly designed/installed. I run Elephant for three reasons. 1. Stiff enough for me. 2. I can install them myself 3. Water sealing issues (i.e. rusty bearings/races) in a place that I can't inspect make me crazy so roller-bearings don't appeal to me in THIS application. The cost-benefit is more than I like since the Elephant solution gives me the ability to lubricate each of them as well, and allows so little deflection that I likely won't be able to tell the difference. Good luck! |
| nsr-jamie |
Jan 18 2011, 03:35 AM
It's a matter of proper handling under heavy turns and severe braking and what that's worth to you. Much of that is related to the stiffness in your spring system, but if we assume the same spring rates in each case, I look at it as an easy decision. Only those I have experience with are listed. The ones you can do yourself: 1. Stock: more deflection, thus more alignment changes during maneuvers. 2. Delrin: Cheap and very stiff but fine if properly installed. They wear out quickest of all of them. 3. Elephant Polybronze: Fairly easy installation, tiny deflection under stress. They're expensive but possibly the last ones the car needs if they are maintained (lubricated) properly. Professionally installed into your suspension arms, 1. Roller bearings: Most expensive, essentially no deflection, bolt-up installation by you. Prone to water intrusion if the seals aren't properly designed/installed. I run Elephant for three reasons. 1. Stiff enough for me. 2. I can install them myself 3. Water sealing issues (i.e. rusty bearings/races) in a place that I can't inspect make me crazy so roller-bearings don't appeal to me in THIS application. The cost-benefit is more than I like since the Elephant solution gives me the ability to lubricate each of them as well, and allows so little deflection that I likely won't be able to tell the difference. Good luck! Thank you for the excellent info...you have the Elephant bushings? These are what I am still thinking about but having problems deciding.... how is the ride? Is your car a pure racer? Or like my car, a weekend fun car that I like to drive and take to the mountains....I don't mind a firm ride....just curious how is your ride and what kind of driving are you doing? (race? DD? fun car? AX?) |
| pcar916 |
Jan 18 2011, 07:34 AM
... just curious how is your ride and what kind of driving are you doing? (race? DD? fun car? AX?) Mine is basically a race car I keep on the street (daily driver) and it's quite stiff, but the stiffness isn't from the bushings. It's from the 23mm front torsion bars, the 22mm front sway-bar, Bilstein sport front inserts, the 200# rear springs, and koni gas adjustable shocks. Road race cars make for the most fun road cars because the elements we face on the road are more like a road-race track than an AX. My car is built for road-track use and it's not set-up to do AX unless I make big changes to soften the front (sway-bar adjustments) and/or stiffen the rear with a shock adjustment... usually both. Plus the clutch-type 60/40 LSD makes for a push on tight AX elements. But as I said it's a daily driver and I live very close to some great mountain roads. I like nothing better than to go out into the twisty roads and push the car. Those Elephant bushings made a dramatic difference in the crispness of my turns. Nothing will make you quicker than confidence that when you make a steering input, that you feel the car respond the same way every time, and that it happens RIGHT NOW! The non-stock bushings don't stiffen the car but they simply do two things: 1. With proper installation they give our swing arms the ability to move freely and NOT become part of the spring equation with drag. That would make them spring-dampeners. 2. They reduce (in directions that steal energy from your steering input) suspension arm movement. The biggest benefit you will get is a crispness in steering that, if you're "tuned" to your car with rubber or old bushings, you will notice immediately. None of these are going to increase the impact of the road on your butt. (IMG:style_emoticons/default/beerchug.gif) That's purely a function of your springs, shocks (which are a kind of spring) and the weight of the car. |
nsr-jamie Looking for some suspension bushing suggestions Jan 16 2011, 09:44 PM
SirAndy Oh boy ... :ducking for cover:
The suspension b... Jan 16 2011, 09:57 PM
mrbubblehead i just installed elephant poly bronze on my rear t... Jan 16 2011, 10:23 PM
phillstek
i just installed elephant poly bronze on my rear ... Jan 16 2011, 10:28 PM
mrbubblehead
i just installed elephant poly bronze on my rear... Jan 16 2011, 10:30 PM
phillstek I've recently installed ER rear bushes in my c... Jan 16 2011, 10:26 PM
mgardstr I'm glad you asked this question so I can ask ... Jan 16 2011, 10:39 PM
SirAndy When the new bushings are installed, should the ar... Jan 16 2011, 10:43 PM
phillstek
When the new bushings are installed, should the a... Jan 17 2011, 12:06 AM
SirAndy When you say roller bearings is that different to ... Jan 17 2011, 12:36 AM
mgardstr SirAndy,
Which is best, sticking or not and what w... Jan 16 2011, 10:50 PM
silver74insocal :idea: this sounds familiar :)
http://www.914wo... Jan 16 2011, 10:52 PM
nsr-jamie
http://www.914w... Jan 17 2011, 03:27 AM
r_towle Jamie,
If you are going stock and want a nice ride... Jan 16 2011, 10:57 PM
nsr-jamie
Jamie,
If you are going stock and want a nice rid... Jan 17 2011, 03:30 AM
nsr-jamie
... just curious how is your ride and what kind ... Jan 19 2011, 06:22 AM
r_towle I installed my bearings...its a simple process and... Jan 17 2011, 09:53 AM
nsr-jamie
I installed my bearings...its a simple process an... Jan 18 2011, 03:32 AM
nsr-jamie Where would be the best place to order Elephant bu... Jan 19 2011, 06:25 AM
Als914
Where would be the best place to order Elephant b... Jan 20 2011, 11:24 AM
tradisrad Elephant Racing is in San Jose. Give Chuck a call ... Jan 19 2011, 08:33 AM
nsr-jamie
Elephant Racing is in San Jose. Give Chuck a call... Jan 19 2011, 09:14 AM
pcar916 No experience with the Rebel Racing bushings but I... Jan 19 2011, 09:48 AM
tradisrad Good point to mention removal of the rear rubber b... Jan 19 2011, 10:57 AM
nsr-jamie Thanks!! This is super helpful!!... Jan 20 2011, 06:06 AM
tradisrad Jamie,
You can do the work your self it is not tha... Jan 20 2011, 10:55 AM
nsr-jamie
Jamie,
You can do the work your self it is not th... Jan 20 2011, 09:40 PM
kg6dxn JB Weld is a two part steel based epoxy. About ... Jan 20 2011, 10:07 PM
nsr-jamie Well, I stopped by the home center on the way home... Jan 21 2011, 05:41 AM
tradisrad If you are installing Elephant poly bronze bushing... Jan 21 2011, 08:31 AM
pcar916 JB-Weld is an epoxy that has steel (or something) ... Jan 21 2011, 08:39 AM
jeff9146 Hi,
You can get JB WELD on Ebay, herewith a link :... Jan 22 2011, 05:39 PM
Eric_Shea Further note with Poly-Bronze and JB Weld: JB Wel... Jan 22 2011, 10:30 PM
rfuerst911sc Another data point. I have ER poly bronze bushings... Jan 23 2011, 05:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 04:51 AM |
