corsepervita |
Member ![]() ![]() Group: Members Posts: 327 Joined: 18-April 10 From: Redmond, OR Member No.: 11,631 Region Association: Pacific Northwest ![]() |
Alright so I'm getting the 914 ready and working out all the kinks after the electrical mishap.
I got it all working, everything tested out fine but I got a weird reaction from my wife... "Your brake lights aren't working did you know that?" and i said "nonsense... look" and i'd go push to the floor and they'd come on. What I wasn't realizing is that it would have to be quite far down before it came on. So of course, i took things apart and looked at the switch and it either looks bent, or something is wrong with the switch. It has to depress quite far before it'll actually kick on. I thought "Hm that's odd." If I try and adjust it by moving it further down the large washer that it is on that goes down with the pedal, it'll actually sometimes go too far and past the washer and bam, no light at all. So I re-adjust it and then it only goes on once it's far down. Although I'm assuming the following shouldn't be the case: Should it have lateral play? I am thinking my switch may be busted. Maybe when I was doing the harness I bumped and bent or broke it, because it has some lateral play instead of going back and forth. Anyone have a picture so I can compare? |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
To adjust the switch....depress the pedal and put a 4mm (0.16") spacer between the pedal stop and the assm. stop...loosen the adjuster lock nut and screw the adjuster screw until the lights come on.....tighten lock nut...remove 4mm spacer and test lights...should come on just after pedal is depressed......click on this link and click on the switch pic... http://www.pelicanparts.com/catalog/shopca...l_pg1.htm#item2
Lo-Fi Version | Time is now: 11th June 2024 - 02:33 AM |
