Looking to mount MSD on battery tray (like ECU), anyone have any pics/suggestions |
moparrob |
Jan 19 2011, 10:44 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
I've searched for about 15 minutes and I can't seem to find any pics. Mine is going on a /6 conversion so no stock ECU (nor bracket to work from).
So has anyone mounted their MSD box off of the battery tray? Any pics? Any reason NOT to do so? I see alot of folks fabbing brackets to the firewall, but I was going to see if the area behind the battery would be a good spot. Should I try to mount the Blaster coil there also? Or just keep it in the stock location? Thanks in advance (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
Jan 20 2011, 10:13 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Yes we have done it and just use the original ignition control unit plate. Makes for a very clean installation
http://www.autoatlanta.com/detail.php?Part...l_number=205997 I've searched for about 15 minutes and I can't seem to find any pics. Mine is going on a /6 conversion so no stock ECU (nor bracket to work from). So has anyone mounted their MSD box off of the battery tray? Any pics? Any reason NOT to do so? I see alot of folks fabbing brackets to the firewall, but I was going to see if the area behind the battery would be a good spot. Should I try to mount the Blaster coil there also? Or just keep it in the stock location? Thanks in advance (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:03 AM |
