| Brett W |
Mar 28 2004, 10:53 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None
Alright I got my first look at a complete LS1 Engine sitting on the floor and not in a car. I measure it for length and hieght. The numbers i came up with are:
Height from bottom of oil pan to top of motor 24.5-25 inches Length from back of head to front of water pump pulley 27.5-28.0 Supposedly the LS1-LS6 wieghs 497 lbs fully dressed. What does the standard 914 V8 small blocked weigh fully dressed? (With all of the Conversion parts) These engines are not cheap right now. I am hearing about 4000 for the complete engine, tranny, computer, and harness. You can sell the tranny for 800-1500 dollars so that may help ease the pain. I would like to try and mooch the motor off my buddy and see what will need to be clearenced to fit it in a 914. I have a feeling that the fire wall will need to be cut to clear the water pump pulley. Any other thoughts on this? |
| Brett W |
Mar 30 2004, 09:40 PM
Steve, I'll give you 4 grand for the front clip.
(IMG:style_emoticons/default/sawzall-smiley.gif) Good luck getting 350+out of a vintage non turbo engine. 911 heads suck. I realize there will be a lot involved. I wouldn't have it any other way. I don't mind cutting the firewall as long as it is done with skill and cleanly modified. I am guessing I will probably have to add at least 3inches to the bump in the firewall and probably have to make a box on the rear for the air intake to pass through. |
Brett W LS1 update Mar 28 2004, 10:53 AM
Bhuntley The only way the engine will fit is by using a ser... Mar 28 2004, 11:14 AM
Brad Roberts RHS doesnt have a kit for the LS1/LS6 engines.
Br... Mar 28 2004, 12:09 PM
Brett W working on them now. Going to try and do a test ... Mar 28 2004, 03:32 PM
BIGKAT_83 <... Mar 30 2004, 08:36 PM
Brad Roberts The fly by wire throttle is easy. Most of them hav... Mar 30 2004, 10:03 PM
airsix <... Mar 30 2004, 11:23 PM
Brad Roberts I assumed he was joking. Hemi chamber.... easy to ... Mar 30 2004, 11:26 PM
Pnambic I could easily be all screwed up here, but I was t... Mar 31 2004, 07:38 AM
Malmz The concept of the rear radiator doesn't seem ... Mar 31 2004, 10:13 AM
Malmz FYI.
http://toy-jet.com/website5.jpg Mar 31 2004, 10:14 AM
Mueller I totally agree with you Steve, that rear spoiler ... Mar 31 2004, 10:34 AM
John2kx <... Mar 31 2004, 04:28 PM
Bigbohr ![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 02:26 PM |
