Camber set up for six, Need some help |
sixaddict |
Jan 23 2011, 10:18 AM
Senior Member Group: Members Posts: 805 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Doing some "work" to get more negative camber up front ...but now trying to decide entirre set up....Been so long since had this done I am forgetting.
RA1, 16 X 225 50 w/ 7.5" wheels front Ditto 16 x 225 45 w/ 8.5 rear Shooting for 2 1/2 negative up front What should I do @ the rear. Mainly DE/track but some autocrossing. Prefer to compromise ax set-up as opposed to track. 2.7 at this time if it matters. Thank for the help Terry |
brilliantrot |
Jan 23 2011, 02:42 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
Negative camber settings are a function of driver aggression, tire construction, and the rest of the suspension set up. When I was running my relatively softly sprung 914-4 on Hoosiers, I had -4 degrees of front camber and tire temps said I needed more. Keeping the car flatter would have reduced the need for more camber.
For the rear, I pulled all the shims out and ran it. At the ride height I was at, that was 2.5 degrees in the rear and tire temps indicated that was about right. My car was stock front T-bars, 22mm front sway bar set most of the way stiff, 200lb/in rear springs and 225/45/15s all the way around. |
J P Stein |
Jan 23 2011, 06:14 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Negative camber settings are a function of driver aggression........ I detect some B Roberts BS here. Testing by GRM some years back showed that camber in excess of -3.5 degrees resulted in loss of braking performance to the detriment of AX times.... In other words, the test drivers started going slower. Those drivers were no slouches. |
brant |
Jan 23 2011, 06:37 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Negative camber settings are a function of driver aggression........ I detect some B Roberts BS here. Testing by GRM some years back showed that camber in excess of -3.5 degrees resulted in loss of braking performance to the detriment of AX times.... In other words, the test drivers started going slower. Those drivers were no slouches. On our 914 racer we noticed the loss of brake ability way before -3.5 we did a test at -3.0 and could tell the increased brake zones over -2.5 but couldn't really detect any better cornering performance. so we never run -3.0 anymore always stay between =2.5 to -2.8 test was run on hoosier R6 we actually have run a set of RA1's, but never dial the car in for them just dial in for the hoosiers as the toyo's are for warm up, enduro's, and rain brant |
Lo-Fi Version | Time is now: 4th June 2024 - 08:05 AM |
