21mm Torsion Bars 4 914/4? |
detoxcowboy |
Jan 24 2011, 09:52 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Is anyone running 21mm torsion bars on a stock 914/4? How stiff is it? Just curious as I know sometimes even the little adjustment/upgrade in the suspension can be more than ideal.. (IMG:style_emoticons/default/confused24.gif)
r_towle |
Jan 24 2011, 10:31 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I did 23mm bars...to stiff.
the best setup is stock torsion bars with a 21mm front anti sway bar and 140-180 lb rear adjustable springs. Run koni adjustable shocks and with all of that underneath you , you can tune your suspension to a premium setup for autox, track or street....depends on your application. rich |
detoxcowboy |
Jan 24 2011, 10:44 PM
I did 23mm bars...to stiff. the best setup is stock torsion bars with a 21mm front anti sway bar and 140-180 lb rear adjustable springs. Run koni adjustable shocks and with all of that underneath you , you can tune your suspension to a premium setup for autox, track or street....depends on your application. rich Thanks Rich! Your input is always one I read anywhere any topic. Right now I am on Billstiens all around with factory fr. and rear sway bars and factory torson bars, new rubber bushings and 100 lb. springs.. It is a nice ride but I am always open to learning, and the front just seems a bit softer than the rear but it is not enough to warrant that much changing or concern really, just knowledge at this point. When I screwed up my first bushing install (poly) they were all pretty much siezed and rode like off road ride everywhere (kidney belt), but it turned/tracked like it was on rails very sweet!.... |
Lo-Fi Version | Time is now: 10th June 2024 - 08:06 PM |
