Ignition Problem or?, Bouncy Tach and Gen Light Flashes |
19144jt |
Aug 10 2010, 09:11 AM
Member Group: Members Posts: 176 Joined: 19-September 05 From: Grass Valley, CA Member No.: 4,829 |
I have been restoring this car for a while (1975 1.8) so it sits from time to time without being started. I am ready to get it running good to start driving it and complete the restoration. Less than a year ago I could reach in from outside the car, turn the key and it would start right up. I just replaced the fuel pump with a new one because the old one quit. Now I have to keep the key turned for maybe 15 to 20 seconds or more before it will fire and then maybe another 10 seconds while it finally catches and starts. It seems to idle fine but if I rev it even slightly from idle the tach starts to bounce wildly and the Generator light flashes on and off steadily and continuously. After searching this site It sounded like I was dealing with a bad condenser so I popped the dist out and changed out the condenser with a spare I had. I also fileld the points to remove any pits etc. and gapped them correctly. Reinstalled the dizzy and no luck...still took a lot of cranking before it would start and as soon as I gave it a little gas above idle the light was back on and the tach bouncing. I am not sure if the long start time (showed up conspicuously after new fuel pump installation) and the light and tach aren't two independant problems. I want to test the cold start valve and switch but it has been too warm to get below the test temp. Any suggestions?
John |
19144jt |
Jan 28 2011, 10:57 AM
Update: This thread was bumped from last August to see if we couldn't figure this out. Here is what has changed since then:
1. I have removed the points and condenser and installed an electronic ignition...Pertronix I believe (it's been a few months). 2. I have corrected the starting problem...had the two hoses attached to the fuel tank swapped from when I changed out the fuel pump, must have had too many beers that night. Now it starts right up even when very cold. 3. I swapped out many voltage regulators to see if that was it...no luck. 4. Removed alternator and regulator and had tested together at a highly reputable electric shop that rebuilds them...test was good for both the alternator and regulator. 5. I will reinstall the alternator this weekend if I survive the 100+ mile ride on my 170 HP Polaris RMK 900 snowmobile in the Sierras! I noticed when I removed it the main red lead was quite corroded and could very well be the problem. John |
Lo-Fi Version | Time is now: 11th June 2024 - 06:21 AM |
