19144jt |
Member ![]() ![]() Group: Members Posts: 176 Joined: 19-September 05 From: Grass Valley, CA Member No.: 4,829 ![]() |
I have been restoring this car for a while (1975 1.8) so it sits from time to time without being started. I am ready to get it running good to start driving it and complete the restoration. Less than a year ago I could reach in from outside the car, turn the key and it would start right up. I just replaced the fuel pump with a new one because the old one quit. Now I have to keep the key turned for maybe 15 to 20 seconds or more before it will fire and then maybe another 10 seconds while it finally catches and starts. It seems to idle fine but if I rev it even slightly from idle the tach starts to bounce wildly and the Generator light flashes on and off steadily and continuously. After searching this site It sounded like I was dealing with a bad condenser so I popped the dist out and changed out the condenser with a spare I had. I also fileld the points to remove any pits etc. and gapped them correctly. Reinstalled the dizzy and no luck...still took a lot of cranking before it would start and as soon as I gave it a little gas above idle the light was back on and the tach bouncing. I am not sure if the long start time (showed up conspicuously after new fuel pump installation) and the light and tach aren't two independant problems. I want to test the cold start valve and switch but it has been too warm to get below the test temp. Any suggestions?
John |
19144jt |
OK, I put the alternator and voltage regulator back in and the gen light was still flashing on and off. Spent most of yesterday working on this. I did finally find that when I removed the turn signal/emergency flasher relay the gen light stopped flashing and simply went to a dull glow and the tach stopped bouncing and that's where I left it. I did check the tach by removing the purple/black wire from the coil as suggested with no change. I went over every wire I could find that came even close to having anything to do with this and no luck. The alternator is charging the battery though at 13.5 to 14 volts when I checked. I couldn't find a master ground under the dash...can you tell me what to look for? I looked for a group of light brown wires and couldn't see anything. I did try unplugging the relay board connectors and plugging them back in but that didn't do it.
Lo-Fi Version | Time is now: 13th July 2025 - 06:48 PM |
