> Remove Engine, How High Do I Need to Lift the Car to Get Engine Out
badboybear
post Feb 2 2011, 11:57 AM
[size=3]How high do I need jack the car up to take the engine out from the bottom? Does anyone have a diagram for removing the engine....what bolts & where to remove, want to drop tranny & motor at once...hopefully.
Also where do I look or go to get a "repair kit" for the HELL HOLE. Told there is a metal replacment type piece? Thanks all,
M&T914
detoxcowboy
post Feb 2 2011, 02:52 PM
Region Association: Africa
914 Engine Removal Made Easy
http://www.pelicanparts.com/techarticles/9...engine_drop.htm
badboybear   Remove Engine   Feb 2 2011, 11:57 AM
Scarlet75   Go to914 info at thhe top and click on Tech articl...   Feb 2 2011, 12:04 PM
SirAndy   Go to914 info at thhe top and click on Tech artic...   Feb 2 2011, 10:43 PM
toon1   I don't know the excact height but it's in...   Feb 2 2011, 12:09 PM
tradisrad   While I dont have an exact height to jack the car ...   Feb 2 2011, 12:17 PM
badboybear   While I dont have an exact height to jack the car...   Feb 2 2011, 12:27 PM
tradisrad   Nah, no blood required. Check your CV bolts; the...   Feb 2 2011, 12:44 PM
silver74insocal   Nah, no blood required. Check your CV bolts; th...   Feb 2 2011, 10:03 PM
stugray   Oh.... AND drain the oil FIRST ;-) I used to be a...   Feb 2 2011, 01:30 PM
badboybear   Oh.... AND drain the oil FIRST ;-) I used to be ...   Feb 2 2011, 02:16 PM
Jerry75914   There is a good article on the PP site "engin...   Feb 2 2011, 02:51 PM
detoxcowboy   914 Engine Removal Made Easy http://www.pelicanpar...   Feb 2 2011, 02:52 PM
badboybear   914 Engine Removal Made Easy http://www.pelicanpa...   Feb 2 2011, 05:39 PM
jt914-6   Don't forget the tranny ground strap..... :hea...   Feb 2 2011, 03:47 PM
stugray   Oh, and use zip ties or coat hangers to hold the a...   Feb 2 2011, 04:22 PM
Jeffs9146   The higher the better!! :blink:   Feb 2 2011, 09:17 PM
Drums66   The higher the better!! :blink: .....Ge...   Sep 2 2011, 12:12 PM
rohar   I took 4 1" 16gauge tubes and drilled some ho...   Feb 2 2011, 10:43 PM
JmuRiz   Experts, I have a couple of questions: What are s...   Sep 2 2011, 11:47 AM
jimkelly   damn scary high for a V8 - slightly less for a 4. ...   Sep 2 2011, 12:01 PM
JawjaPorsche   Do I see antifreeze on the driveway? Be sure to k...   Sep 2 2011, 12:09 PM
Dave_Darling   The rear of the car needs to be about 2" high...   Sep 2 2011, 07:11 PM
Kirmizi   Having done this recently, I'd suggest taking ...   Sep 2 2011, 08:06 PM
Vacca Rabite   High. I put my jackstands on 4x4 timbers. Make s...   Sep 2 2011, 08:26 PM
bigkensteele   I swear by the "threaded rod" method. Y...   Sep 2 2011, 08:26 PM
larss   I swear by the "threaded rod" method. ...   Sep 2 2011, 11:06 PM
rhodyguy   with carbs on a 4 if you remove the carbs as an as...   Sep 3 2011, 08:23 AM
- Lo-Fi Version Time is now: 11th July 2025 - 08:43 AM
