badboybear
Feb 2 2011, 11:57 AM
[size=3]How high do I need jack the car up to take the engine out from the bottom? Does anyone have a diagram for removing the engine....what bolts & where to remove, want to drop tranny & motor at once...hopefully.
Also where do I look or go to get a "repair kit" for the HELL HOLE. Told there is a metal replacment type piece? Thanks all,
M&T914
AndyB
Feb 2 2011, 12:04 PM
Go to914 info at thhe top and click on Tech articles. Thats how I dropped mine good luck
toon1
Feb 2 2011, 12:09 PM
I don't know the excact height but it's in the 18" range. Depending o the jack or dolly that you are going to use to set the engine on will determine the height.
most of the bolts and nuts will be 10-14 mm. with the exception of the main motor mount and the trans. mount bolts which are 17mmIIRC.
The motor is not difficult to remove, just make sure everything is disconnected and it will drop right down.
with NO experience at doing this, it's about a 2.5 hour job.
For the seasoned "pro" 45min to an 1.5 hours alone.
tradisrad
Feb 2 2011, 12:17 PM
While I dont have an exact height to jack the car up to I can offer some tips.
Disconnect fuel lines, clutch & throttle cables, battery, CVs (they dont need to be removed but must pass over the engine) & trans ground strap + any misc wiring the engine may have & any emission hoses.
1st dont raise the car so high that your jack wont reach the eng/trans.
2nd it is helpful to remove the air cleaner and injectors (injectors may catch on the suspension "ears")
3rd drop it as a package eng/trans
I place a 3/4" thick piece of plywood on the jack and center it near the fly wheel, maybe slightly forward. It is helpful to have a friend or two during the removal process, however it can be done solo.
Check Auto Atlanta or Restoration Design for you replacement parts.
With some experience the engine can be removed in an hour and a half to two hours (or less time in some garages)
I find it easier to disconnect the trans mounts instead of the nuts off of the 2 mounting bolts.
Good luck, it's only scary the first time.
badboybear
Feb 2 2011, 12:27 PM
QUOTE(tradisrad @ Feb 2 2011, 10:17 AM)
Thanks & yes scared...sort of, not like getting married...LOL. I will also check out the tech articles and the other places mentioned. Appreciate all very much....stay tuned I know I'm gonna bust a knuckle...OUCH!
tradisrad
Feb 2 2011, 12:44 PM
Nah, no blood required.
Check your CV bolts; they should be a 12pt (triple square) socket, although they may have been replaced with the incorrect regular Allen socket. This is a "special" tool that you may need.
stugray
Feb 2 2011, 01:30 PM
Oh.... AND drain the oil FIRST ;-)
I used to be able to do the whole job in 1 hour with a carb engine.
FI is just a little more complicated.
Stu
badboybear
Feb 2 2011, 02:16 PM
QUOTE(stugray @ Feb 2 2011, 11:30 AM)
Stu
Thanks guys...really do appreciate it & we'll drain ALL fluids first...lol
Mike
Jerry75914
Feb 2 2011, 02:51 PM
There is a good article on the PP site "engine drop made easy". I just used it a few weeks ago on my first engine drop...did it solo, no issues. I did need to get it pretty high up, around 30" with the rear valance removed if I remember right...but I could also have removed more from teh engine first.
Watch out for it getting hung up on the suspension console...it is a REALLY tight fit going down.
be patient, and you'll be fine, good luck!
detoxcowboy
Feb 2 2011, 02:52 PM
jt914-6
Feb 2 2011, 03:47 PM
Don't forget the tranny ground strap.....
stugray
Feb 2 2011, 04:22 PM
Oh, and use zip ties or coat hangers to hold the axles up in the air (or take them all the way off) and put sandwich baggies over the CVs or you will end up with grease everywhere.
Trying to work around them is a PITA.
"Don't forget the tranny ground strap...."
Oh, no you can forget it....... it will just tear off or leave the tranny hanging and you wonder "what the heck"..... BTDT
badboybear
Feb 2 2011, 05:39 PM
QUOTE(detoxcowboy @ Feb 2 2011, 12:52 PM)
Downloaded info and thanks guys...ladies if your out there. I won't forget the tranny ground strap either...hope this works. Things we do to save a buck...lol!!
Jeffs9146
Feb 2 2011, 09:17 PM
The higher the better!!
silver74insocal
Feb 2 2011, 10:03 PM
QUOTE(tradisrad @ Feb 2 2011, 10:44 AM)
WAHT!! all 914's require a blood offering before leaving the jackstands...might as well get it out of the way now
good luck..i have used the pelican method a few times on my own just take your time and check everyhting twice...
Dave
rohar
Feb 2 2011, 10:43 PM
I took 4 1" 16gauge tubes and drilled some holes through them. Just long enough to bolt to the front hubs and keep the disks off the ground.
If you drop the front of the car a bit, you don't have to jack it up as high at the middle of the car. Don't have to use chalks in the front either.
QUOTE(Scarlet75 @ Feb 2 2011, 10:04 AM)
This was good advice ... It's all here ...
http://www.914world.com/specs/tech_engdrop1.php
JmuRiz
Sep 2 2011, 11:47 AM
Experts, I have a couple of questions:
What are special instructions for cars with carbs?
What are special instructions for using a lift to remove the engine?
Thanks, I may be trying my first engine drop this weekend.
jimkelly
Sep 2 2011, 12:01 PM
damn scary high for a V8 - slightly less for a 4.
be sure to check the front wheels very well.
and go under as briefly as possible.
JawjaPorsche
Sep 2 2011, 12:09 PM
Do I see antifreeze on the driveway? Be sure to keep your dogs away!
QUOTE(jimkelly @ Sep 2 2011, 02:01 PM)
Drums66
Sep 2 2011, 12:12 PM
Dave_Darling
Sep 2 2011, 07:11 PM
The rear of the car needs to be about 2" higher than it will go with regular jack-stands on the "donuts" and the front wheels on the ground. That's assuming you pull the intake and oil filler off the engine, but forget the dipstick (D'OH!) and have the engine sitting on a floor jack with a piece of wood for a cushion. Then, if you're motivated, you can push the back of the car up a little higher by hand while your buddy pulls the engine the rest of the way out.
If you put the engine down on a dolly, or a piece of wood, or some such, you'll have more clearance.
If you have any question at all about the clearance available, just remove everything from the top of the engine. Carbs, manifolds, distributor, oil filler, dipstick. You need less clearance that way. Make sure to cover the openings so you don't drop dirt or tools or fasteners down into the engine.
--DD
Kirmizi
Sep 2 2011, 08:06 PM
Having done this recently, I'd suggest taking some pics with a digital camera so you have a reference point for the inevitable "hmm, where'd this go" moments during reassembly.
Mike
VaccaRabite
Sep 2 2011, 08:26 PM
High.
I put my jackstands on 4x4 timbers. Make sure the car is stable! Give it a good shake test.
Pulling the engine is not hard. Its easier to raise the car off the engine then to lower the engine out of the car. A lifting plate from Tangereen (Racer Chris here on the boards) makes it easier still.
The first time is intimidating. it gets easier after that. Pulling the engine is not all that hard. Unhooking everything is what is the PITA.
Zach
bigkensteele
I swear by the "threaded rod" method. You get the car up on stands and then put your jack under each side of the engine bar. Remove the nut and bolt and replace with 18" piece of 3/8" threaded bar with a double nut on the top, and a nut with a flat washer on the bottom. Then you put your jack under the end of the tranny. This allows for COMPLETE control of the lowering process at 3 points. AND no problem whatsoever doing it alone. You just loosen the bottom nut on each side incrementally to lower the front of the engine and lower the jack to move the back.
Works just as well to get it back in.
Sure it takes a while to crank down/up all those threads if you use a regular wrench, but I bought a cheap set of ratcheting wrenches from HF, and it is all good.
I lower it straight down onto an HF furniture dolly, and I can wheel it right out.
My problem was getting it up onto an engine stand. Mine was so covered with grime that I was not about to ask a couple of friends to come over and risk a hernia or possible smashed foot to get it up there, so I had to rent an engine hoist. 30 bucks, problem solved in less than an hour. Now that it is all clean, and the chance of dropping it due to hands slipping on grease is greatly diminished, I may lower it back down using the "friend" method.
larss
Sep 2 2011, 11:06 PM
QUOTE(bigkensteele @ Sep 3 2011, 04:26 AM)
I use the "threaded rod" (M10 rod) method also, this is since Im alone and it is a safe method for both me and the engine.
I use a second jack at the front which lifts/lowers the engine so the rods are mostly unloaded (and really just there for safety) making it easy to twist the rod nuts by hand as the engine goes up or down.
/Lars S
rhodyguy
Sep 3 2011, 08:23 AM
with carbs on a 4 if you remove the carbs as an assembly leaving the linkage intact you'll buy yourself a bunch of room and preserve your current linkage adjustment. remove the 8 nuts securing the carbs to the intakes, disconnect the throttle cable, lift carbs off, and a paper towel in each runner to keep stray items out of the engine.
k
