machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
I have these things on my fuel system, didn't realize that you just cut the hose, oil, and insert the end.
Are these things safe? Seems too easy. I was planning on using these for my -12 oil lines. dr |
machina |
Aeroquip already did that.
Assembly rated at 300deg continuous at 250 psi. The AQP has the same temp rating but a much higher pressure margin, 500 => 1000 psi. Jake said he has seen 300psi on very cold startup but I think the socketless is probably OK for a racecar, maybe not for a race airplane. dr |
Lo-Fi Version | Time is now: 1st August 2025 - 10:59 AM |
