> 914 engine oil breather, Is it really necessary
recko911
post Feb 17 2011, 12:05 AM
Is a oil breather filter really necessary on the engine case.
gothspeed
post Feb 17 2011, 11:41 AM
Definitely vent! Also make sure you use the factory check-valve, it keeps the crankcase from building too much pressure, which will help prevent oil leaks.
ChrisFoley
post Feb 17 2011, 12:09 PM
I am Tangerine Racing
QUOTE(gothspeed @ Feb 17 2011, 12:41 PM) *
Definitely vent! Also make sure you use the factory check-valve...
Only when the factory injection is retained should the stock valve be left intact. We gut the PCV valve on every breather installation, but still use it as a connection point in most cases. The stock valve is a restriction to good ventilation.
- Lo-Fi Version Time is now: 4th July 2025 - 07:35 AM
