> rear radiator setups?, Has anyone seen or heard of them being done successfully
chuckc
post Feb 18 2011, 09:56 PM
I can think of a few reason why a rear radiator set up for a conversion would be a bad idea, but has anyone seen or heard of them being done successfully, maybe with ducting running out to vents infront of rear fenders and a custom shroud? Just curious.
peace,
Chuck
Chris Hamilton
post Feb 18 2011, 10:12 PM
I'm building one soon. If you don't find one by then you can look at mine (IMG:style_emoticons/default/biggrin.gif)
Cons versus putting in front trunk:
-Weight balance could be worse depending on what you want to do.
-Poor shrouding or sucking hot air off the motor could lead to inadequate cooling.
Pros
-No water lines running to front.
-Less overall water line length and therefore weight.
-Better aerodynamics in the front end.
chuckc   rear radiator setups?   Feb 18 2011, 09:56 PM
Chris Hamilton   I'm building one soon. If you don't find o...   Feb 18 2011, 10:12 PM
kg6dxn   There is a thread on this site with a rear radiato...   Feb 18 2011, 10:18 PM
Bruce Hinds   Air across the back is pretty dead and creating ae...   Feb 18 2011, 10:21 PM
RJMII   my first 914 I was running a mid radiator setup. T...   Feb 19 2011, 12:02 PM
sean_v8_914   WCC 2005 Scott drove his Suby conversion from MD t...   Feb 19 2011, 01:09 PM
rick 918-S   WCC 2005 Scott drove his Suby conversion from MD ...   Feb 19 2011, 03:52 PM
SirAndy   WCC 2005 Scott drove his Suby conversion from MD ...   Feb 19 2011, 04:20 PM
Bruce Hinds   i guess it just depends on how much you want to co...   Feb 19 2011, 02:35 PM
Brujo65   I know is not a 914 but my vw ghia with rear radia...   Feb 19 2011, 06:34 PM
timothy_nd28   :bump: Checking in to see if anyone has made this...   Nov 10 2014, 05:59 PM
chris914   For a stock setup I put one in the back by the rea...   Nov 10 2014, 06:12 PM
skeates   I think it comes down to horsepower. You might be ...   Nov 10 2014, 06:53 PM
Andyrew   I think if you had a subaru trani setup and moved ...   Nov 10 2014, 10:43 PM
porsche913b_sp   Hit up Robert about coolant tempts on his rotary. ...   Nov 11 2014, 12:01 AM
timothy_nd28   Hit up Robert about coolant tempts on his rotary....   Nov 11 2014, 02:00 PM
Andyrew   [quote name='porsche913b_sp' post='2109099' date=...   Nov 11 2014, 02:42 PM
monkeyboy   [quote name='porsche913b_sp' post='2109099' date...   Nov 11 2014, 04:10 PM
Mike Bellis   While the engine lid radiator sounds like a good i...   Nov 11 2014, 04:26 PM
timothy_nd28   Just received a confirmation that the rain tray sl...   Nov 11 2014, 05:01 PM
76-914   FWIW, I wanted to take this opportunity to dispel ...   Nov 12 2014, 09:46 AM
- Lo-Fi Version Time is now: 11th March 2026 - 09:27 AM
