| quadracerx |
Feb 19 2011, 02:57 PM
Member ![]() ![]() Group: Members Posts: 428 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Ok....so Project Rusty begins in earnest today....I will start a thread as soon as work is completed this weekend...and yes I have pictures of what is possibly the most rusted 914 on the planet....more on that later....
Im working on removing the front suspension as a complete unit.... So far: Removed master cylinder. Removed Cover that hides the suspension crossmember. Removed Fuel Tank. Removed "clamp on steering column under gas tank". Removed brake lines that go to front calipers from body brackets. So all I have to do now is: 1) Remove bolts (4 ea) on torsion bars up front (is it necessary to remove the front valance?). 2) Remove the suspension crossmember bolts (2 ea). 3) Remove two upper strut mount nuts (I know about the tabs that lock the nuts, any easy way to bend these back out of the way?). 4) Remove the 8mm allen bolts surrounding the upper strut mount. Is there anything else Im forgetting? This is alot of fun...but I should own some stock in PB Blaster...you'll see what I mean when I start posting pics... Thanks guys, again for all your help. Steve |
| Dave_Darling |
Feb 19 2011, 05:00 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The tabs on the strut washers are not that hard to bend down. Though I wound up using a hammer and the screwdriver to do it. I had a friend use a pipe wrench to hold the washer while I broke the nut loose.
Don't forget the steering rack! You either have to separate the ball joints, or remove the tie rods, or unbolt the rack from the body and from the steering column. --DD |
quadracerx Front Suspension Removal... Feb 19 2011, 02:57 PM
quadracerx Is the clamp on the top side under the gas tank th... Feb 19 2011, 05:36 PM
silver74insocal i wouldnt remove the allens on the top of the stru... Feb 19 2011, 06:53 PM
dion9146
i wouldnt remove the allens on the top of the str... Feb 20 2011, 07:24 AM
quadracerx Is the clamp on the top side under the gas tank th... Feb 22 2011, 04:38 PM
r_towle You need to go inside the car and remove the u-joi... Feb 22 2011, 04:55 PM
jaxdream If you pulled the tank and removed the 2 bolts tha... Feb 22 2011, 05:02 PM
quadracerx Dangit....
I was hoping that I wouldnt have to cl... Feb 22 2011, 07:52 PM
jaxdream Pull the plastic accordian cover up off the rack u... Feb 23 2011, 07:38 AM
Eric_Shea
There should be three each up front. 2 17mm on t... Feb 23 2011, 10:24 AM
quadracerx Phase One Complete...
Thanks EVERYONE.....Wooo Ho... Feb 23 2011, 07:01 PM
Eric_Shea Alright... I'll bite. What is the 20mm for? ... Feb 23 2011, 10:41 PM
quadracerx As weird as this seems....20mm is what actually fi... Feb 23 2011, 11:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 09:58 AM |
