HF transmission jack, How did it work? |
Randal |
Feb 21 2011, 12:07 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
First time putting the engine in the car with this jack. Also the first time I did it solo. Really the only problem was supporting the transmission. As Chris pointed out the balance point is behind the engine, so had to get creative. I do need to look at Chris's platform to see if it would work with the bottom of my engine (tuna can and exterior oiling system). Otherwise something will have to be built to extend back and support the transmission. Being able to adjust the engine side to side really helped getting the cross bar into position to bolt down. I did have to jack up the transmission up to meet that acute angle of the car. FYI the lower engine sheet metal was 35" above ground. Taking the one set of TB's off worked great, no problems with clearance, other than trying to do the job without screwing up the plumbing or electrical for the FI. Now I have to start the exercise to hook up everything, which is a bit more complicated on this engine than most. Especially the oiling system. After two years I found myself looking for the pictures I took before I removed the engine. Where did my memory go? (IMG:style_emoticons/default/rolleyes.gif) |
Borderline |
Feb 21 2011, 09:44 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
WOW! Looks pretty busy in there. I like to keep things simple so I can understand them. hehehehe Those velocity stacks look nice. Where are they from? What size injector stacks are you running? I think you need to show off the welding on that cage of yours. Those Tig welds are beautiful! (IMG:style_emoticons/default/biggrin.gif)
Randal |
Feb 22 2011, 12:02 AM
WOW! Looks pretty busy in there. I like to keep things simple so I can understand them. hehehehe Those velocity stacks look nice. Where are they from? What size injector stacks are you running? I think you need to show off the welding on that cage of yours. Those Tig welds are beautiful! (IMG:style_emoticons/default/biggrin.gif) Those are TRW's. The ones on the car are 45mm. I have another set, but I think they are smaller. Tomorrow I'll measure them for you. Yea the tig welding is very nice. I think I'm going to just clean the crome moly bars and put on some w-40. Might look OK. Update: The extra set of velocity stacks have a 45mm opening. |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:45 AM |
