> Front Suspension Removal...
quadracerx
post Feb 19 2011, 02:57 PM
Ok....so Project Rusty begins in earnest today....I will start a thread as soon as work is completed this weekend...and yes I have pictures of what is possibly the most rusted 914 on the planet....more on that later....
Im working on removing the front suspension as a complete unit....
So far:
Removed master cylinder.
Removed Cover that hides the suspension crossmember.
Removed Fuel Tank.
Removed "clamp on steering column under gas tank".
Removed brake lines that go to front calipers from body brackets.
So all I have to do now is:
1) Remove bolts (4 ea) on torsion bars up front (is it necessary to remove the front valance?).
2) Remove the suspension crossmember bolts (2 ea).
3) Remove two upper strut mount nuts (I know about the tabs that lock the nuts, any easy way to bend these back out of the way?).
4) Remove the 8mm allen bolts surrounding the upper strut mount.
Is there anything else Im forgetting? This is alot of fun...but I should own some stock in PB Blaster...you'll see what I mean when I start posting pics...
Thanks guys, again for all your help.
Steve
Eric_Shea
post Feb 23 2011, 10:24 AM
PMB Performance
There should be three each up front. 2 17mm on the sides of each front mount and one 7 or 8mm cap/cheesehead under the cover. Depending upon the valance, it may need to be removed to get at that cheesehead. If it's stock, yes.
There should be 2 large 19mm bolts and two more 17mm on the body tabs.
As mentioned earlier, just remove the strut mounts (22 or 24mm depending). Leave the others and your upper bushings will remain in the car.
It can be a pain because you're yanking the R&P with the suspension. Because of the angle with the splines etc. it will act like it doesn't want to come out. You may want to simply remove those 2 17mm bolts on the rack and pull it seperately.
- Lo-Fi Version Time is now: 3rd March 2026 - 09:59 AM
