HF transmission jack, How did it work? |
Randal |
Feb 21 2011, 12:07 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
First time putting the engine in the car with this jack. Also the first time I did it solo. Really the only problem was supporting the transmission. As Chris pointed out the balance point is behind the engine, so had to get creative. I do need to look at Chris's platform to see if it would work with the bottom of my engine (tuna can and exterior oiling system). Otherwise something will have to be built to extend back and support the transmission. Being able to adjust the engine side to side really helped getting the cross bar into position to bolt down. I did have to jack up the transmission up to meet that acute angle of the car. FYI the lower engine sheet metal was 35" above ground. Taking the one set of TB's off worked great, no problems with clearance, other than trying to do the job without screwing up the plumbing or electrical for the FI. Now I have to start the exercise to hook up everything, which is a bit more complicated on this engine than most. Especially the oiling system. After two years I found myself looking for the pictures I took before I removed the engine. Where did my memory go? (IMG:style_emoticons/default/rolleyes.gif) |
ChrisFoley |
Feb 21 2011, 10:29 PM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I do need to look at Chris's platform to see if it would work with the bottom of my engine (tuna can and exterior oiling system). Have I ever let you down Randal? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
Randal |
Feb 21 2011, 11:58 PM
I do need to look at Chris's platform to see if it would work with the bottom of my engine (tuna can and exterior oiling system). Have I ever let you down Randal? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) Nope. Never. And your stuff works! Can't wait to get this puppy back on the dyno. |
grantsfo |
Feb 23 2011, 03:54 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I do need to look at Chris's platform to see if it would work with the bottom of my engine (tuna can and exterior oiling system). Have I ever let you down Randal? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) Nope. Never. And your stuff works! Can't wait to get this puppy back on the dyno. Will be cool to see wheel dyno on that motor. Do you use a Dyno Jet? Would really be interested in SAE corrected numbers you see. I'm turning into sort of a Dyno nerd since my new sponsor gives me free dyno time on his Dyno Jet. I have done something like 30 pulls in a few weeks! I make a change and I'm on the dyno. I never realized the amount of variation in Dyno numbers until I spent more time on one. I now realize that high Dyno number really doesnt reflect true operating conditions so we do several pulls with engine in various stages of warm and cool. Especially important with era of electronics. I can see 15 HP variances just based on engine temps alone. Dont think I will ever look at quoted dyno numbers the same. I do about 4 or 5 passes after mods and compare those passes to previous passes at base line. If all the passes show improvement then I feel comfortable that I have made right changes. |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:00 AM |
